Pistal2k Posted May 2, 2021 Posted May 2, 2021 I’m using windows 7 and when I plug the usb from my aimtrak gun and start hyperspin it goes crazy causing the hyperspin wheel to keep spinning not allowing me to pick any gameconsole until I disconnect it. Can someone help me with this problem I would greatly appreciate it. If your up for the task you can remotely connect to my computer to see what going on. Also i have a dual boot system with windows 7 64 but and windows 10 64 bit. It doesn’t do it on the windows 10 side
gigapig Posted May 3, 2021 Posted May 3, 2021 Have you configured your controls in HyperHQ? If so you should have just set up keyboard controls and nothing else as they don't work, you will have to use a keymapper or the startup script.
