Running Batch Files Through Hyperspin - Demul Shooter/Sega Model 2
drudru21
I'm looking for help running games as batch files through Hyperspin.  I found one tutorial video online and I followed these steps through Rocket Launcher:
- Created batch files that run outside of Hyperspin and Rocket Launcher.  The batch files load Demul Shooter with a command line to run the game and emulator.
- Added Bat extensions to the emulator in Rocket Launcher
- Updated database xml to show Bat files
Through Hyperspin, I was able to select the Bat file and it "loaded" but the game never actually ran and I was sent back to Hyperspin.
I appreciate any feedback!
There's probably a better way to do this, @ninja2bceen has a good video tutorial.
It's generally not a good idea to use batch files at all. If you absolutely must, it might be best to convert those bats to exe and then use the PCLauncher module.
Thanks for the suggestions, would you happen to have any links to that tutorial video? I'm searching but he has produced a ton of tutorial videos.
I'm not familiar with converting bats to exe, but I'll give that a try, thanks for the suggestion!
