Daphne in 16*9 when run
tester007
I'm trying to get a dragon's Lair cab finished off. Everything seems to work fairly well. I have the guts of a PC in the cab, and ultimarc arcadevga card feeding into a standard res CRT arcade monitor. To be able to see anything on the screen, it has to be set to pretty low resolutions which make working on this fairly difficult, as an LCD monitor won't run. I have it set to 640*288. When windows runs, it's offset to the right a bit which doesn't matter as it boots right into hyperspin. HS looks fine, and fills the 4:3 monitor perfectly, and only shows Daphne games. However, when a game is run, they are in more of a 16*9 mode with black bars at the top and bottom of the screen. I've read online some people editing the Daphne module, stating to get to that through one of the 3 shortcuts (sorry not in front of the screen to remember the name of which, but the one you chose the emulator, edit the wheel..etc). They all say on the right of the screen, click "modules" and edit away. However, I don't have a link like that under any of the tabs.
Does anyone know how I can get the laser games to play 4:3?
You get crickets because this is not a common problem. All Daphne games are 4:3. You monitor is 4:3. It should be fine. It must have to do with your odd resolution. 640x480 is 4:3 so maybe try that. I do not own a CRT so I am only guessing really.
