StevieMac Posted July 3, 2014 Posted July 3, 2014 I had this all working at one point then while fiddling with wheels, artwork & joypads I've screwed something up & can't find an answer. All of the games work fine when loaded from HyperLaunch or HyperLaunchHQ but in Hyper spin I can go to all games with the GUI working fine but when I load a game I get this error then it disappears & Hyperspin carry's on. Here's the errors for just 2 but this is the same for all emulators now. Cannot Find C:\HYPERS~1\Hyperspin\Emulators\Project64\Project641.6\Project64.exe Cannot Find C:\HYPERS~1\Hyperspin\Emulators\MAME\mame64.exe I've looked at a few threads on here but none seem to have the same error message as me. I tried rfancella's sudgestion of turning off HyperLaunch enabled in HyperHQ which worked for MAME but for the others gave me no error but no game loads. Thanks for the help guys. If you need any info I'm a bit new to all this so just say what you need & how to get it & I'll post the info. Steve
rfancella Posted July 3, 2014 Posted July 3, 2014 I had this all working at one point then while fiddling with wheels, artwork & joypads I've screwed something up & can't find an answer. All of the games work fine when loaded from HyperLaunch or HyperLaunchHQ but in Hyper spin I can go to all games with the GUI working fine but when I load a game I get this error then it disappears & Hyperspin carry's on. Here's the errors for just 2 but this is the same for all emulators now. Cannot Find C:\HYPERS~1\Hyperspin\Emulators\Project64\Project641.6\Project64.exe Cannot Find C:\HYPERS~1\Hyperspin\Emulators\MAME\mame64.exe I've looked at a few threads on here but none seem to have the same error message as me. I tried rfancella's sudgestion of turning off HyperLaunch enabled in HyperHQ which worked for MAME but for the others gave me no error but no game loads. Thanks for the help guys. If you need any info I'm a bit new to all this so just say what you need & how to get it & I'll post the info. Steve Steve, If you are using HLHQ and HyperLaunch, you must have HyperLaunch enabled in HyperHQ. If they launch ok in HLHQ then check your path to HyperLaunch. Open the file .../HyperSpin/Settings/Settings.ini You should have a line that says: Hyperlaunch_Path= at the bottom of your [Main] section. This points to the directory that has your hyperlaunch.exe file in it. If you have the correct directory structure it should look like this: Hyperlaunch_Path=HyperLaunch\ You should have ...\HyperSpin\HyperLaunch\HyperLaunch.exe I have seen this issue if there is more than one HyperLaunch.exe and your setup is trying to use an old HyperLaunch. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
StevieMac Posted July 3, 2014 Author Posted July 3, 2014 Hey Ron thanks for the speedy reply. So all Emu's need to have HyperLaunch enabled in HyperHQ under the wheel tab? You should have ...\HyperSpin\HyperLaunch\HyperLaunch.exe - Yes this is correct. I checked the Settings.ini file & I don't have Hyperlaunch_Path= in the file?! I've not touched any of this so I've no idea why it screwed now. C:\Hyperspin\Settings\Settings.ini [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=SNK Neo Geo [Resolution] FullScreen=false Width=800 Height=600 Scanlines_Active=false Scanlines_Image= Scanlines_Scale=2 Scanlines_Alpha=0.1 [Optimizer] CPU_Priority=normal Quality=HIGH Image_Smoothing=true Animated_Backgrounds=true Inter_Backgrounds=false Level1_Backgrounds=true Level2_Backgrounds=true Level3_Backgrounds=false Level4_Backgrounds=false Special_Backgrounds=true Wait_For_Special=false Animated_Artworks=true Level1_Artworks=true Level2_Artworks=true [introVideo] Use_Intro=false Stop_On_Keypress=true [sound] Master_Volume=100 Video_Volume=100 Wheel_Volume=20 Interface_Volume=100 [AttractMode] Active=true Time=60 MaxSpinTime=10 HyperSpin=true Wait_For_Video=false [Keyboard] Key_Delay=true [P1 Controls] Start=13 Exit=27 Up=38 Down=40 SkipUp=37 SkipDown=39 SkipUpNumber=70 SkipDownNumber=86 HyperSpin=32 Genre=71 Favorites=76 [P2 Controls] Start=69 Exit=81 Up=87 Down=83 SkipUp=65 SkipDown=68 SkipUpNumber=74 SkipDownNumber=77 HyperSpin=88 Genre=72 Favorites=90 [P1 Joystick] Enabled=true Joy=0 Threshold=10 Start=Button_3 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Button_7 SkipDown=Button_5 SkipUpNumber=Button_8 SkipDownNumber=Button_6 HyperSpin=Button_13 Genre=Button_9 Favorites=Button_7 [P2 Joystick] Enabled=false Joy=1 Threshold=40 Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 [Trackball] Enabled=false Sensitivity=90 [spinner] Enabled=false Sensitivity=90 [startup Program] Executable= Paramaters= Working_Directory= WinState= [Exit Program] Executable= Paramaters= Working_Directory= WinState=NORMAL [LEDBlinky] Active=false Path= [HiScore] Active=false Y=550 Delay=2
StevieMac Posted July 3, 2014 Author Posted July 3, 2014 Ok thanks Ron I added that line to the settings.ini file and now everything seems to be working again. I've no idea what got rid of it but thanks for the speedy help as usual mate!! Steve
rfancella Posted July 4, 2014 Posted July 4, 2014 Ok thanks Ron I added that line to the settings.ini file and now everything seems to be working again. I've no idea what got rid of it but thanks for the speedy help as usual mate!! Steve Steve, Your very welcome! And thank you for the kind words. I have heard of other users that have had such strange stuff happen as well. Often it is some other software running in the background (maybe anti-virus) that will wipe out a file. I have seen some very strange stuff happen. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
