Snes9x Test Setup
Bedwyr
Hi. I'm a new user, but I'll try to keep details short and to-the-point.
Problem: Hyperspin program does not load or limit current audited games as set in HyperHQ and tested in HyperlaunchHQ.
Program Versions:
  • Snes9x 1.53
  • Hyperspin 1.3.2
  • HyperHQ 1.3.0
  • HyperLaunchHQ 1.0.13 (RocketLauncher from GIT repository)
  • Hypermatch 1.0
  • Hypersync Cloud 3.5.0
Program Locations:
  • Snes9x (D:\Games\Emulators\SNES\ ; D:\Games\Emulators\SNES\Roms)
  • Hyperspin (D:\Games\Emulators\Hyperspin\)
  • HyperLaunchHQ (D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunchHQ)
Current Setup so far:
  1. I have the system loaded in HyperlaunchHQ, emulator set to global, extensions smc|sfc, Snes9x.ahk module, Snes9x set to default emulator, full screen settings in the emulator.
  2. Two games renamed via Hypermatch as a test.
  3. Game runs appropriately when test launched from HyperlaunchHQ.
  4. HyperHQ set to multi, SNES wheel set to Hyperlaunch, Rom and Exe paths provided (full path set), Wheel filter Roms only.
Behavior when launching Hyperspin:
The program loads and pressing enter when on the SNES screen causes the SNES screen to reload; no games. [edit] Other systems in Hyperspin load their default configuration, ie- loading the entire game database with a sample title configured, such as Goldeneye for N64.
System configuration:
Other than having SSD on C:\, storage on D:\, and a general preference for separating emulator folders and Hyperspin folder structure as above, I don't *think* system specs are an issue. I can provide on request though. It's a fairly beefy HTPC/Steam Box.
Thanks in advance for your help.
Also, I followed these instructions as best I could:
http://www.hyperspin-fe.com/forum/showthread.php?29481-How-to-install-HyperSpin
(Fifthdread's video)
(Giga Guide's Zsnes setup instructions)
Once I successfully get this set up, I want to program the X360 Home button to exit games. I'll either look for Hyperspin to do this or make a switch to RetroArch loading either a Snes9x core or BSnes core. Any heads-up warnings welcome.
New Update as I attempt to troubleshoot. I found these threads:
http://www.hyperspin-fe.com/forum/showthread.php?28080-Hyperlaunch-3-0-doesn-t-work-in-hyperspin
http://www.hyperspin-fe.com/forum/showthread.php?28351-Hyperlaunch-will-not-run-from-Hyperspin-after-update&p=269363&viewfull=1#post269363
  1. I checked settings.ini and verified "Hyperlaunch_Path=D:\Games\Emulators\Hyperspin\Hyperlaunch\"
  2. Tried running Hyperspin as admin and reduced UAC to its lowest setting (I'm in Windows 8.1) with no change.
  3. Looking at log.txt: "10:29:55 AM | No roms found ". I went back into HyperlaunchHQ and verified with an audit that it does, in fact, find two games and I can successfully test launch them. I'm really at a loss at this point.
Ok, solved one problem and found another.
In HyperlaunchHQ, the extensions are separated by vertical line. In HyperHQ, they are separated by a comma. I now get the proper menu, but was only able to load intermittently.
New log:
12:19:02 PM |  Launching Game
12:19:02 PM |  Using HyperLaunch
12:19:02 PM |  Getting HyperLaunch path
12:19:02 PM |  HyperLaunch located at D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe
12:19:02 PM |  Running HyperLaunch.exe
12:19:02 PM |  HyperLaunch Command Line is: D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe "Super Nintendo Entertainment System" "ActRaiser (USA)"
12:19:11 PM |  Launching Game
12:19:11 PM |  Using HyperLaunch
12:19:11 PM |  Getting HyperLaunch path
12:19:11 PM |  HyperLaunch located at D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe
12:19:11 PM |  Running HyperLaunch.exe
12:19:11 PM |  HyperLaunch Command Line is: D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe "Super Nintendo Entertainment System" "ActRaiser 2 (USA)"
12:19:14 PM |  Launching Game
12:19:14 PM |  Using HyperLaunch
12:19:14 PM |  Getting HyperLaunch path
12:19:14 PM |  HyperLaunch located at D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe
12:19:14 PM |  Running HyperLaunch.exe
12:19:14 PM |  HyperLaunch Command Line is: D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe "Super Nintendo Entertainment System" "ActRaiser 2 (USA)"
12:19:18 PM |  Launching Game
12:19:19 PM |  Using HyperLaunch
12:19:19 PM |  Getting HyperLaunch path
12:19:19 PM |  HyperLaunch located at D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe
12:19:19 PM |  Running HyperLaunch.exe
12:19:19 PM |  HyperLaunch Command Line is: D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe "Super Nintendo Entertainment System" "ActRaiser 2 (USA)"
12:19:20 PM |  Launching Game
12:19:20 PM |  Using HyperLaunch
12:19:20 PM |  Getting HyperLaunch path
12:19:20 PM |  HyperLaunch located at D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe
12:19:20 PM |  Running HyperLaunch.exe
12:19:20 PM |  HyperLaunch Command Line is: D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe "Super Nintendo Entertainment System" "ActRaiser 2 (USA)"
12:19:21 PM |  Launching Game
12:19:21 PM |  Using HyperLaunch
12:19:21 PM |  Getting HyperLaunch path
12:19:21 PM |  HyperLaunch located at D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe
12:19:21 PM |  Running HyperLaunch.exe
12:19:21 PM |  HyperLaunch Command Line is: D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe "Super Nintendo Entertainment System" "ActRaiser 2 (USA)"
12:19:24 PM |  Launching Game
12:19:24 PM |  Using HyperLaunch
12:19:24 PM |  Getting HyperLaunch path
12:19:24 PM |  HyperLaunch located at D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe
12:19:24 PM |  Running HyperLaunch.exe
12:19:24 PM |  HyperLaunch Command Line is: D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe "Super Nintendo Entertainment System" "ActRaiser (USA)"
12:19:30 PM |  Exit program unavailable
12:19:30 PM |  Quiting Hyperspin
12:19:30 PM |  Bye!
I loaded ActRaiser correctly the first time, but ActRaiser 2 did not load the second time, nor did ActRaiser 1 the second time.
Ok, new update. I solved one problem. HyperlaunchHQ separates file extensions by vertical line. HyperHQ wants commas. The menu loads correctly and I got ActRaiser running the first time. However subsequent attempts to run either ActRaiser 2 or 1 failed.
The new log:
12:19:30 PM |  Bye!
Ok, testing one more post. I think the previous two got eaten by anti-spam measures and await moderation, but I couldn't read the post-message quickly enough. Just to be clear, I got the menu loading correctly but my test game only loads the first time. Will post log once I'm sure I can post again.
[edit] Ok it worked. Let's see if I can insert the log text now. I loaded ActRaiser 1 just fine the first time but couldn't load either 1 or 2 subsequent times:
12:19:30 PM |  Bye!
[edit 2] Ok, progress. I can only launch games when Hyperlaunch is not resident in memory (task tray). How do I ensure the Hyperlaunch.exe program completely exits once I press Esc? I understand AutoHotKey is integral to Hyperlaunch operation. Does the fact that AHK is also resident have something to do with this? (I'll go test that theory.)
[edit 3] No. AHK has nothing to do with it. Hyperlaunch.exe simply fails to clear. I'll search for a similar issue on the forums.
you will get better help if you post your correct log
you posted the Hypespin log witch tells us very little.
the correct log to post is in your hyperlaunch folder.
Hyperlaunch/hyperlaunch.txt
this log would of told of all of this
Program Versions:
Snes9x 1.53
Hyperspin 1.3.2
HyperHQ 1.3.0
Program Locations:
HyperLaunchHQ (D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLau nchHQ)
and much much more.
You mean Hyperlaunch.log? I see no *.txt.
12:54:27:774 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1c
12:54:27:824 | HL |     INFO  | +47    | Main - System Specs:
				HyperLaunch Dir: D:\Games\Emulators\Hyperspin\Hyperlaunch
				OS: Microsoft Windows 8.1
				SKU: Windows 8
				Total Memory: 8072.55 MB
				Free Memory: 5388.35 MB
				Used Memory: 2684.199 MB
				SystemType: x64-based PC
				Physical Processors: 1
				Logical Processors: 4
				GPU 1 Name: Intel(R) HD Graphics 4600
				GPU 1 RAM: -1984.00 MB
				GPU 1 Driver Version: 10.18.10.3316
				GPU 2 Name: NVIDIA GeForce GTX 660
				GPU 2 RAM: -2048.00 MB
				GPU 2 Driver Version: 9.18.13.3221
				Sound 1 Device: NVIDIA High Definition Audio
				Sound 1 Status: Enabled
				Sound 2 Device: High Definition Audio Device
				Sound 2 Status: Enabled
				Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
				Sound 3 Status: Enabled
				Sound 4 Device: High Definition Audio Device
				Sound 4 Status: Enabled
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work)
				AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe
				AHK Version: 1.1.09.04
				Unicode: No
12:54:27:824 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
12:54:27:824 | HL |     INFO  | +0     | CheckFile - Checking if D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.exe exists
12:54:27:824 | HL |     INFO  | +0     | Main - HyperLaunch received "Super Nintendo Entertainment System" and "ActRaiser (USA)"
12:54:27:827 | HL |     INFO  | +15    | Main - ActRaiser (USA) is using the default emulator: Snes9x
12:54:27:827 | HL |     INFO  | +0     | Main - Checking for a [snes9x] section in D:\Games\Emulators\Hyperspin\Hyperlaunch\Settings\Super Nintendo Entertainment System\Emulators.ini
12:54:27:827 | HL |     INFO  | +0     | Main - Checking for a [snes9x] section in D:\Games\Emulators\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini
12:54:27:827 | HL |     INFO  | +0     | Main - Found [snes9x] in D:\Games\Emulators\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini
12:54:27:828 | HL |     INFO  | +0     | CheckFile - Checking if D:\Games\Emulators\Hyperspin\Hyperlaunch\Modules\Snes9x\Snes9x.ahk exists
12:54:27:831 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
12:54:27:831 | HL |     INFO  | +0     | Main - ActRaiser (USA) will use module: D:\Games\Emulators\Hyperspin\Hyperlaunch\Modules\Snes9x\Snes9x.ahk
12:54:27:837 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
12:54:27:839 | HL |     INFO  | +0     | Main - INI Keys read
12:54:27:839 | HL |     INFO  | +0     | CheckFile - Checking if D:\Games\Emulators\Hyperspin\Hyperlaunch\Module Extensions\7z.exe exists
12:54:27:839 | HL |     INFO  | +0     | CheckFile - Checking if D:\Games\Emulators\Hyperspin\Hyperlaunch\Module Extensions\7z.dll exists
12:54:27:840 | HL |     INFO  | +0     | CheckPaths - Started
12:54:27:840 | HL |     INFO  | +0     | CheckPaths - Found rom: D:\Games\Emulators\SNES\Roms\ActRaiser (USA).smc
12:54:27:840 | HL |     INFO  | +0     | CheckFile - Checking if D:\Games\Emulators\SNES\snes9x.exe exists
12:54:27:840 | HL |     INFO  | +0     | CheckPaths - Ended
12:54:27:840 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				hlMode =
				frontendPID = 4964
				frontendPath = D:\Games\Emulators\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = D:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = D:\Games\Emulators\SNES\snes9x.exe
				emuPath = D:\Games\Emulators\SNES
				emuName = Snes9x
				emuExt = exe
				romPath = D:\Games\Emulators\SNES\Roms
				romPathFromIni = D:\Games\Emulators\SNES\Roms
				romExtension = .smc
				romExtensionOrig = .smc
				romExtensions = smc|sfc
				executable = snes9x.exe
				systemName = Super Nintendo Entertainment System
				dbName = ActRaiser (USA)
				romName = ActRaiser (USA)
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				blockInputTime = 0
				blockInputFile =
				errorLevelReporting = false
				logFile = D:\Games\Emulators\Hyperspin\Hyperlaunch\HyperLaunch.log
				logLevel = 3
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = true
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Media\Fade
				HLDataPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Data
				HLMediaPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Media
				HLErrSoundPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Media\Sounds\Error
				modulesPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Modules
				moduleFullName = D:\Games\Emulators\Hyperspin\Hyperlaunch\Modules\Snes9x\Snes9x.ahk
				moduleName = Snes9x
				modulePath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Modules\Snes9x
				moduleExtension = ahk
				moduleExtensionsPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Module Extensions
				libPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Lib
				7zEnabled = false
				7zPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Module Extensions\7z.exe
				7zDllPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Module Extensions\7z.dll
				7zExtractPath = C:\Users\Michael\AppData\Local\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 0
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper =
				xpadderFullPath = D:\Games\Emulators\Hyperspin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = D:\Games\Emulators\Hyperspin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\HyperSpin
				defaultProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\_Default
				systemProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\Super Nintendo Entertainment System
				xPadderSystemProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\Super Nintendo Entertainment System\_Default
				emuProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\Super Nintendo Entertainment System\Snes9x
				romProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\Super Nintendo Entertainment System\ActRaiser (USA)
				HyperLaunchProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\HyperLaunch
				blankProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\\blank
				ahkFEProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\AHK\_Default
				ahkSystemProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\AHK\Super Nintendo Entertainment System
				ahkEmuProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\AHK\Super Nintendo Entertainment System\Snes9x
				ahkRomProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\AHK\Super Nintendo Entertainment System\ActRaiser (USA)
				ahkHyperLaunchProfile = D:\Games\Emulators\Hyperspin\Hyperlaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
12:54:27:843 | HL |     INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts
12:54:27:843 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
12:54:27:843 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = Snes9X
				MEmuV =  v1.53
				MURL = http://www.snes9x.com/
				MAuthor = djvj
				MVersion = 2.0.1
				MCRC = 34FD2149
				iCRC = FD5A1CE
				MID = 635038268923820476
				MSystem = "Nintendo Super Famicom","Super Nintendo Entertainment System"
				; Notes:
				; Fullscreen is controlled via the variable below
				; snes9x adjusts the windowed resolutions in the ini automatically based on the settings you choose below.
				; Bezels work, but if you notice a black bar along the bottom, change this option to false in snes9x.conf: ExtendHeight
				StartModule()
				BezelGUI()
				FadeInStart()
				EmulateFullscreen := IniReadCheck(settingsFile, "Settings", "EmulateFullscreen","true",,1)		; This helps fading look better and work better on exit. You cannot use this with a normal fullscreen so one has to be false
				WindowMaximized := IniReadCheck(settingsFile, "Settings", "WindowMaximized","true",,1)
				Stretch := IniReadCheck(settingsFile, "Settings", "Stretch","true",,1)
				MaintainAspectRatio := IniReadCheck(settingsFile, "Settings", "MaintainAspectRatio","true",,1)
				HideMenu := IniReadCheck(settingsFile, "Settings", "HideMenu","true",,1)
				FullScreenWidth := IniReadCheck(settingsFile, "Settings", "FullScreenWidth","1024",,1)
				FullScreenHeight := IniReadCheck(settingsFile, "Settings", "FullScreenHeight","768",,1)
				snes9xConf := CheckFile(emuPath . "\snes9x.conf")
				BezelStart()
				; Now let's update all our keys if they differ in the ini
				iniLookup =
				( ltrim c
				   Display\Win, Fullscreen:Enabled, %Fullscreen%
				   Display\Win, Fullscreen:EmulateFullscreen, %EmulateFullscreen%
				   Display\Win, Window:Maximized, %WindowMaximized%
				   Display\Win, Stretch:Enabled, %Stretch%
				   Display\Win, Stretch:MaintainAspectRatio, %MaintainAspectRatio%
				   Display\Win, Fullscreen:Width, %FullScreenWidth%
				   Display\Win, Fullscreen:Height, %FullScreenHeight%
				   Display\Win, HideMenu, %HideMenu%
				Loop, Parse, iniLookup, `n
				{	StringSplit, split, A_LoopField, `,, %A_Space%%A_Tab%
					IniRead, tempVar, %snes9xConf%, %split1%, %split2%
					If ( tempVar != split3 )
						IniWrite, % split3, %snes9xConf%, %split1%, %split2%
				Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath)
				WinWait("Snes9X ahk_class Snes9X: WndClass")
				WinWaitActive("Snes9X ahk_class Snes9X: WndClass")
				BezelDraw()
				FadeInExit()
				BezelExit()
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				CloseProcess:
					FadeOutStart()
					WinClose("Snes9X ahk_class Snes9X: WndClass")
				Return
12:54:27:845 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
12:54:27:845 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
12:54:27:845 | HL |     INFO  | +0     | Main - Module is built
12:54:27:845 | HL |     INFO  | +0     | CheckFile - Checking if D:\Games\Emulators\Hyperspin\Hyperlaunch\AutoHotkey.dll exists
12:54:27:846 | HL |     INFO  | +0     | Main - Running module
12:54:27:935 | MD |     INFO  | +N/A   | Module initialized
12:54:27:956 | MD |     INFO  | +31    | StartModule - Started
12:54:27:956 | MD |     INFO  | +0     | StartModule - MEmu: Snes9X
				MEmuV: v1.53
				MURL: http://www.snes9x.com/
				MAuthor: djvj
				MVersion: 2.0.1
				MCRC: 34FD2149
				iCRC: FD5A1CE
				MID:
				MSystem: "Nintendo Super Famicom","Super Nintendo Entertainment System"
12:54:27:956 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Super Nintendo Entertainment System"
12:54:27:956 | MD |     INFO  | +0     | StartModule - Ended
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - EmulateFullscreen: true
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - WindowMaximized: true
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - Stretch: true
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - MaintainAspectRatio: true
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - HideMenu: true
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - FullScreenWidth: 1024
12:54:27:956 | MD |     INFO  | +0     | Module Setting - [settings] - FullScreenHeight: 768
12:54:27:956 | MD |     INFO  | +0     | CheckFile - Checking if D:\Games\Emulators\SNES\snes9x.conf exists
12:54:27:957 | MD |     INFO  | +0     | Run - Running: D:\Games\Emulators\SNES\snes9x.exe "D:\Games\Emulators\SNES\Roms\ActRaiser (USA).smc"
12:54:27:974 | MD |     INFO  | +16    | WinWait - Waiting for "Snes9X ahk_class Snes9X: WndClass"
12:54:28:111 | MD |     INFO  | +140   | WinWaitActive - Waiting for "Snes9X ahk_class Snes9X: WndClass"
12:54:28:216 | MD |     INFO  | +110   | Process - WaitClose snes9x.exe
12:54:29:024 | MD |     INFO  | +797   | WinClose - Closing: Snes9X ahk_class Snes9X: WndClass
12:54:29:249 | MD |     INFO  | +234   | ExitModule - Started
12:54:29:249 | MD |     INFO  | +0     | Starting Updating Statistics:
12:54:29:249 | MD |     INFO  | +0     | CreateRomTable - Started
12:54:29:249 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
12:54:29:318 | MD |     INFO  | +63    | Game section statistics updated.
12:54:29:319 | MD |     INFO  | +0     | ExitModule - Ended
12:54:29:319 | MD |     INFO  | +0     | End of Module Logs
