atetheprincess Posted July 4, 2014 Posted July 4, 2014 Followed this guide to the letter:http://www.hyperspin-fe.com/forum/showthread.php?29481-How-to-install-HyperSpin Now when I go in I select mame, it goes to the game list, I hit enter and nothing happens. Nothing at all. When I'd tried setting it up myself it would show an error, now that it's been set up properly I get no errors, but it also doesn't work, lol. Any ideas from some veterans?
gigapig Posted July 4, 2014 Posted July 4, 2014 How did you set up Mame in HyperHQ? Did you add the path to the emulator, Roms and the extension? Did you check any boxes under wheel filters? If so, temporarily remove them.
atetheprincess Posted July 4, 2014 Author Posted July 4, 2014 How did you set up Mame in HyperHQ?Did you add the path to the emulator, Roms and the extension? Did you check any boxes under wheel filters? If so, temporarily remove them. Just noticed the guide neglects HyperHQ. Went in and added my emulator and rom paths. Don't know what it wants for extension? I didn't touch any wheel filters.
gigapig Posted July 4, 2014 Posted July 4, 2014 Extension should be "zip", but if you haven't touched HyperHQ then maybe it's not related. Can you launch from HLHQ? Post your logs if your still having troubles.
atetheprincess Posted July 4, 2014 Author Posted July 4, 2014 Extension should be "zip", but if you haven't touched HyperHQ then maybe it's not related. Can you launch from HLHQ?Post your logs if your still having troubles. I CAN launch from HLHQ. log.txt
gigapig Posted July 4, 2014 Posted July 4, 2014 Oh, is Hyperlaunch running in task manager by any chance? if so end the process and try again.
atetheprincess Posted July 4, 2014 Author Posted July 4, 2014 Oh, is Hyperlaunch running in task manager by any chance? if so end the process and try again. OMG IT WORKS!!!! Thank you so, SO much!
