Hypersin runs, but will not launch game after a recent update for windows 10
hollywood6964
So I have the same build on on an arcade that isn't ran that much, is on windows 10 and gets updates, but not as many since it's not always on. It runs fine there and launches games.
However, some recent update (I don't know which, I don't run hyperspin on my main computer that much) has caused games to not launch through hyperspin. They will just fine through rocketlauncher, or just retroarch.When I hit enter on a game, it does nothing, the I just have to exit hyperspin. I tried to download and reinstall the latest hyperspin, and same thing. Here is the log I have, main thing I'm seeing is it can't find hyperlaunch.....something changed or maybe an update is a problem (probably an update in the last 6 months), anybody have a solution for this?
12:27:53 PM |  HyperSpin Started
12:27:53 PM |  Going FullScreen
12:27:53 PM |  Checking for updates
12:27:53 PM |  Update Check Complete
12:27:53 PM |  Startup program unavailable
12:27:53 PM |  Playing intro video
12:27:54 PM |  Menu Mode is multi
12:27:54 PM |  Loading Main Menu.xml
12:27:54 PM |  Main Menu.xml successfully loaded
12:27:55 PM |  Main Menu wheel loaded successfully
12:27:56 PM |  Loading MAME.xml
12:27:56 PM |  Main Menu.xml successfully loaded
12:27:56 PM |  MAME wheel loaded successfully
12:28:12 PM |  MAME wheel loaded successfully
12:28:28 PM |  Launching Game
12:28:28 PM |  Using HyperLaunch
12:28:28 PM |  Getting Launcher path
12:28:28 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
12:28:28 PM |  Launcher located at E:\Hyperspin\HyperLaunch.exe
12:28:28 PM |  Running Launcher
12:28:28 PM |  Launcher Command Line is: E:\Hyperspin\HyperLaunch.exe "MAME" "cadash"
12:28:35 PM |  Loading Main Menu.xml
12:28:35 PM |  Main Menu.xml successfully loaded
12:28:35 PM |  Main Menu wheel loaded successfully
12:28:36 PM |  Exit program unavailable
12:28:36 PM |  Quiting Hyperspin
12:28:36 PM |  Bye!
What version of windows do you have now?
Check Antivirus and Defender stuff and add exceptions to HS, try also to run HS as Admin (not suggested but it might resolve the issues)
Check also the path of your Hyperlaunch in Settings.ini
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Atari Lynx
Hyperlaunch_Path=C:\HyperSpin_1.5.1\RocketLauncher\RocketLauncher.exe
[Main]
Menu_Mode=multi
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
I got it. Computer kept reassigning the portable hd to F, instead of E like it should be. So it was reverting to hyperlaunch and not working. Thanks for the .ini example, exacting what it was.
