Tonybhoy Posted December 6, 2023 Posted December 6, 2023 I have an arcade with 10‘s of thousands of games, but only have the Mame games activated its in a pub and set up for coin credits before i try adding a couple of the old console games (which are already on it, just not accessible in the menu), how does it work? If i add fifa98 for playstation 1 for example…. Can coins be set up to play one full game? A second coin credit for 2 players? or is it pointless bothering with this as the games were never out on arcade to begin with?
dark13 Posted December 6, 2023 Posted December 6, 2023 Basically pointless. All you can do is map "start p1" on coin1 and "start p2" on coin2 but not every game will work this way and if someone put a coin while playing the emulator will pause. Arcade bootlegs with consoles had some added circuitry to push start only after the coin was inserted Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
Tonybhoy Posted December 6, 2023 Author Posted December 6, 2023 Fair enough…. Someone told me that it was possible to link to a timer…so 1 credit would get you 5 minutes for example but i think that would only work if it was set for all games and impossible to change to a normal coin based system depending on the game
dark13 Posted December 7, 2023 Posted December 7, 2023 19 hours ago, Tonybhoy said: Fair enough…. Someone told me that it was possible to link to a timer…so 1 credit would get you 5 minutes for example but i think that would only work if it was set for all games and impossible to change to a normal coin based system depending on the game Is it a PC or a PandoraBox? If it is a PC I think you can make it also with AHK but I have no idea about the logic to start a game and how to show remaing time. Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
Tonybhoy Posted December 8, 2023 Author Posted December 8, 2023 21 hours ago, dark13 said: Is it a PC or a PandoraBox? If it is a PC I think you can make it also with AHK but I have no idea about the logic to start a game and how to show remaing time. aye its a pc, I’ll look into it cheers
dark13 Posted December 8, 2023 Posted December 8, 2023 Wow, I have only 3238 games on 0.259 (no mahjong no casino no clones no rythm games, no consoles stuff etc) and i'ts not even a "safe" list as some games are listed as not working (es strider 2, you can play it from start to finish but if you press jump, fire and a direction at the same time it will freeze). If you are using Hyperspin and you want a custom skin for your machines you can PM me Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
