PC games and trainers
Styphelus
Is there a way to launch a trainer ahead of a PC game through hyperpsin? I guess I can use a batch file but how would I go about closing it after?
Is there an alternative way of doing this other than batchfiles?
Yes, I know it's cheating but there are some games where I just don't have the patience to get through the normal way (Dark souls, Dark souls 2, The Withcer, Resident Evil 4).
you could use the Pre-Launch, Post-Launch, and Post-Exit options on the PC launcher module for running scripts or executables.
Read here if you are interested on it for more details:
https://sites.google.com/site/hyperlaunch2/additional-features/pclauncher
When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS!
Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher).
Ass. Bleasby - RocketLauncher Development Team.
I used the Pre-launch and Post-Exit options to play a game that was running at 24Hz. There was a fix (to get it at 60Hz) that needed to be launched before the game, and I used a batch file to kill the process once the game was closed.
Since it's basically how trainers work I guess it should work in your case.
I can help to set this up if you need to.
Thanks.
I managed to get it started, however I can't seem to be able to close the trainer on exit. I created a batch file and added it to Post Exit as you mentioned
The batch contents:
taskkill /f /fi "IMAGENAME eq trainer.exe"
However that does not kill the task. The game exits properly but the trainer stays on the screen. I always have to click the X on the top right corner of the trainer to close it. I tried 3 different trainers for 3 different games and all with the same result.
Hmm. I use that command line in my batch file :
taskkill /f /im "Name.exe"
Just make sure the name.exe matches the trainer's processus and it should work.
