nofxbam Posted August 1, 2014 Posted August 1, 2014 Hi All, Was hoping to find my solution by reading related posts but I've tried a lot with no luck. EPSXE works fine on it's own outside of Hyperspin, loading cue files. The problem I'm having is when I load a game in Hyperspin, the emulator stays in a black screen and seems to not load the game. I'm running through HyperlaunchHQ with Daemon Tools "true" and a SCSI drive "true". The cue naming convention is correct with the XML, which loads them on the wheel. Rom path is correct, extensions are set in HyperHQ as cue, bin, ecm and HyperLaunchHQ as cue|bin|ecm. I just downloaded HyperLaunchHQ a week ago so I can't imagine module are out of date. Not sure what the disconnect is with Hyperspin. Any ideas?
nofxbam Posted August 1, 2014 Author Posted August 1, 2014 What version of EPSXE are people here running with Hyperspin? I've got 1.9 and maybe it's not compatible with HyperLaunchHQ?
nofxbam Posted August 2, 2014 Author Posted August 2, 2014 OK fixed my problem. Interesting because the fix is contradictory to everything I've read! I went into HyperLaunchHQ > Sony Playstation > Settings > DAEMON TOOLs = false SCSI = false There ya go...
Retro Goonie Posted August 28, 2014 Posted August 28, 2014 Dude, you're a life saver! Switching both fields to "false" worked for me! I was pulling my hair out for an hour trying to get ePSXe to work. I followed all the tutorials perfectly but kept getting "error loading ePSXe.exe, closing module". Thanks nofxbam!!! My Artwork! Carts: GCE Vectrex 2D Carts (Realistic Version) 1.0, GCE Vectrex 2D Carts (Vector Version) 1.0 Pointers: NEC PC Engine Pointer(s), NEC SuperGrafx Pointer(s), Sega SG-1000 Pointer(s), Sega TecToy Pointer(s), Sega Mega Drive Japan Pointer(s), Nintendo 64 Pointer(s)
nofxbam Posted August 28, 2014 Author Posted August 28, 2014 Retro Goonie said: Dude, you're a life saver! Switching both fields to "false" worked for me!I was pulling my hair out for an hour trying to get ePSXe to work. I followed all the tutorials perfectly but kept getting "error loading ePSXe.exe, closing module". Thanks nofxbam!!! Dude I feel your pain...glad it worked!
