NeoRaine Screen Resolution Issue
Jon.Damico
I have been having an issue with setting up NeoRaine. When I exit the emulator the Hyperspin window is only on 3/4 of my screen. I have had this issue before and since then have changed all my emulators screen resolutions to 1024X768, it seems to be the most common resolution. I could not find an area to change the screen resolution on the NeoRaine GUI, so I edited the config file, without luck either. So has anyone managed to change the resolution on NeoRaine? If not is there a way to force a resolution upon an emulator using HLHQ or another program? Or am I over looking something?
Thanks.
Bump.
I normally don't like bumping, but I have tried everything I can think of. I edited the NeoRaine config file, Set the restore Front end to Restore in HLHQ, but nothing seems to fix this guy. I followed all of the instructions on the module. I have tried changing settings within NeoRaine like video rendering and others. I did notice that NeoRaine automatically changes any setting in the config file back to 1280X720. Did anyone have issues with this or how is everyone getting Neo Geo CD to work?
Thanks.
Well another few days of working on it and no success. I tried every possible combination of video settings, I tried setting it up in windowed mode, this emulator works great, just not in the way I am trying to use it.
I can get it to boot fine, but getting Hyperspin back is the problem. Sometimes the Hyperspin screen size is extremely tiny, other times it appears fine, and then other times it doesn't come back at all. Is there anything I could add to the module to fix this issue, or is this emulator on the scrap list?
If anyone has this working, PLEASE, I'M BEGGING YOU, post what version and your video settings. If anyone has any idea on a way to edit the module, I would also appreciate that. I am going to try to edit the module and if I find something useful I will post back.
Thank You for your help.
I had the same issue with visualboyadvance-m. I tried eveything I could think of. Then I switched to mednafen and there is no issue. Not the answer you want to hear but maybe you should switch to mess or mame.
I did not know MAME ran Neo Geo CD's, It isn't listed in HLHQ. I thought my only other option was Mess, which I tried to set up months ago with another system and had no luck. I have been told that NeoRaine emulates the games with better accuracy and quality, but if it is between having it or not, I will have to give Mess a try tomorrow.
On another note, I started looking into an AutoHotKey zoom. I have been combining and editing some code that allows for a zoom. I set it up to center my mouse, then zoom in on full screen. This way I can have the emulator in windowed mode and zoom in on it, since I only have the issue with the Fullscreen mode. I tried to add it to the module, but it seems to conflict with the fade and then AutoHotKey Launcher errors. haha. So, it may just be simpler to give Mess a try.
Thanks for your help.
By the way we live like 20 minutes from each other. haha.
I couldn't remember which neo geo system neoraine was for. Mame is only for mvs and aes. I have neo geo cd running in mess with no issues.
I used to live in ontario 5-6 years ago.
