Where do I put the bios folders and keys for some emulators that requires it
I have an emulators requires a bios or keys it works outside of hyperspin. But when I try to use hyperspin to launch the games, it does not work. I was wondering if I need to make a bios folder in hyperspin or hyper launch
State what the system and emulator is and maybe someone will be able to help.
  • Upvote 1
Duckstation,mame,cemu so far they will work in the emulators by itself and in launchbox which I’m switching from. With your system do I put bios and keys directly in the emulators or like  Botocera you make a main for bios/key folder in the system it self which one do I need to do. If I need to make a main bios/key File do I put in a sub folder or a folder by itself in the system
Duckstation,cemu,mame so far
Are you using Hyperspin 1.5 or the newer 2.0 version ?
If using 1.5 you need to be using Rocketlauncher in conjunction with Hyperspin and all the modules that Rocketlauncher uses will load all your games as intended.
there is nothing special you need to do with any bios files if your emulators are loading games normally.
if trying to use newer 2.0 version don’t bother , it’s light years from being anywhere near playable.
Hyperspin 2 latest update
OK so any system that takes bios and keys is a no go thanks for letting me know
