changing rom path in HLHQ isn't taking effect
starsixtynin
After moving some stuff around in my network I went into each 'Emulator.ini' file, in the hyperlaunch folder, for each of my emu's and updated the rom_path to the new network location where my roms are stored.
But when running hyperspin and launching a rom it says it can't find said rom and it displays my OLD rom location. However if I run hyperlaunch separately it opens up the NEW network location just fine. Is there another location where the rom_paths are stored?
hmm I would have 2 hyperlaunch.exe's in my hyperspin folder? I'll have to look for it. I went out of town for the weekend and I'll check it when I get back and reply with an update. Thanks
Make sure you edit the HyperSpin directory in your 'HyperSpin>Settings' folder as well.
albert and ghutch thanks for pointing me in the right direction. Changing the directory for hyperlaunch in the settings.ini under HyperSpin>Settings fixed it. Since my HyperSpin directory also changed with my roms directories. Everything seems to be back up and running again. Thanks guys
