HyperSpin Shelled on Windows 7 Solved and Working!
whiLd
I have a full write up on how to do this from a new installation of windows 7 x64 pro with all the needed files to completely shell to hyperspin,no windows logo,boot animation or welcome screen but waiting to finish a few things on my hyperspin build first.The welcome screen is the biggest pain in the arse but once you have the correct stuff in stalled first it is an easy method of replacing a few files and running a few things before rebooting and having no windows to think about.I am using xbmc as boot and hyperspin launching from xbmc,great for the tv with a big web browser and full media playback as well as all the games you could ever want to play.
HERE IS A VID
I hope you all don't think i am showing off,i give my wee brother updates on how i am getting on with hyperspin and sometimes make a vid when i have completed quite a lot on it so he can see what i keep going on about to him on the phone.
  • 1 month later...
  • Replies 159
Added 3 new links to the original post.
  • Remove Microsoft Logo at bottom of Welcome Screen
  • Remove/Modify Welcome Txt
  • 2 Boot Animations for download
First 2 links provided by Shaolin.
The 3rd link provided by Baglio.
.:whiLd:.
View HyperSpin Apps for featured HyperSpin 3rd party apps, and app news.
To view my cabinet build album, click here
Change Boot Animation: Windows 7 Boot Updater
this was working perfectly before for me.. then all of a sudden stopped working .. a few times when I used instant sheller for changing mouse icon to dot .. it would reset the boot animation.. but id just change it back to the one I want and it would work
but now it no matter what I do with Windows 7 Boot Updater something is instantly changing it back to the windows stuff.
I can hit Apply.. close it.. and reopen it.. and it loads the Windows stuff.
Any ideas?
Baily, try disabling instant sheller then re-enable Windows 7 boot updater.
Restart your PC.
See if that works.
If it does, then you can manually change your mouse cursor to the black dot manually in the Windows Control Panel. (Mouse Options)
If it doesn't work:
Try a Windows restore point to a time where the bout animation worked.
Sent from my DROIDX using Tapatalk
.:whiLd:.
Excellent, thanks for the write-up. Will help me massively :)
Np, glad we could help! :)
.:whiLd:.
  • 3 weeks later...
A couple of questions on this:
What I'm looking for is a way to use this cabinet without any mouse or keyboard at all. I'd like to hit a power switch and go straight into HS. Your solution seems to accomplish this (though I havent' tried it yet) however... I'm wondering how you manage shutting down the computer.
You said above that you can exit HS and then go into task manager to start windows. Okay, that's cool. I would've thought though that once you exit HS, your computer would shut down. If that's not the case then how do you shut down the computer? Do you just hit the power switch? Does it matter if it doesn't shut down properly since Windows isnt' running?
Also, I saw a Mame graphic that people used with Bootskin. Could this be used as a boot up graphic in this solution?I love the skin that was posted here. The blue graphic part way down just looks great. Could I use this with your solution? http://www.wincustomize.com/explore/bootskins_xp/7965/
This one actually looks better but its not animated: http://www.wincustomize.com/explore/bootskins_xp/7982
<em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
Okay, that's cool.
If I use that though, how do I exit into windows if I want to load MP3s, games, updates etc...
Does Hyperspin have to keep running in the background when I do this? How do you get around that?
Also, in regards to the boot graphics... can I use those graphics? If so, how do I get the animation to work?
This is all explained in the first post.
Close HS like you normally would. Esc or a mapped button.
Ctrl+Alt+Del
Open task manager
File
New task
type "explorer" (without the quotes)
Hit enter
Welcome to windows ;)
.:whiLd:.
This is also explained in the first post. I have a link that takes you to an external tutorial. Follow the tutorial and it will work just fine.
There are different animation programs that you can use.
The animation needs to be saved in a series of .png files if I recall correctly.
There are also already created animations out there for use.
Hope this helps!
.:whiLd:.
Once I do this though, wouldn't the system shut down on me before I could do anything else?
Ctrl+Alt+Del
Open task manager
File
New task
Hit enter
This seems straightforward enough if the CTRL-ALT-Delete can be done before it shuts down. I'm guessing there's enough time to do this after Exit then?
Also, does all of this work for 64 bit? Do I need to do anything differently if it is 64 bit?
Thanks for your help.
If your HS is setup to shut down the computer on exit, you will not be able to exit to windows after choosing to shut down HS.
You can either Ctrl+Alt+Del and start the explorer task without closing HS. This will leave HS running in the background while you are in windows.
Or make HS close on shut exit, not shutting down the computer.
Then just shut down the computer from the start menu.
Or hold the power button. (not recommended)
.:whiLd:.
Oh yeah. My tutorial is for 64 bit.
.:whiLd:.
I'm guessing this would be my only option as I want to be able to turn on and off the cabinet without a mouse or keyboard. On the occassions that I do want to go into windows, I guess I'll just have to have HS on in the background.
I used Boot Updater to change the screen. I found it to be a bit hard to use.
I had an image that I wanted to use as the background and I had to keep manually shrinking it to get it to fit.
I found out that once you take a large background option you no longer are able to put in text.
Also, I thought that you could download animated gifs for this but I guess not. This is too bad because I was kind of hoping to be able to put in an animated pac-man as the progress bar and having "loading under it"
Anyways, I downloaded a pre-made Hyperspin skin and have a big Mame background over top so it doesn't look too bad. Thanks for that tip.
Hey,
Not sure how I can post pics on this. I restarted my computer and then tried to hit "print screen" but I couldn't paste it into anything.
I also tried to use the preview in Updater but unfortunately it doesn't show the background picture in there, only the HS animation.
Any way that I can take a picture from the restart? I'll be happy to do it for you if you tell me how.
Use your phone or digital camera.
.:whiLd:.
Here it is. I realized that if the "complete background" was going to hide my text... I could just add my own in the bitmap, so that's what I did. The "hyperspin logo" is the animated one that I got from Deviant art.
http://imageshack.us/photo/my-images/843/bootscreenl.jpg/
The screen really needs a Pac-man animation on it... I've got an animated .gif but I can't figure out how to do it with updater.
Looks good.
"Welcome to the machine" reminds me of Pink Floyd. ;)
.:whiLd:.
Ctrl+Alt+Del
Open task manager
File
New task
Hit enter
silly question but couldnt you just edit the PC Games module game path
[street Fighter IV]
; gamePath = C:\Program Files (x86)\CAPCOM\STREETFIGHTERIV\sfiv.exe
; params =
and just point to C:\windows\explorer.exe to get HS to launch explorer
