Nestopia losing focus
jhartley111
Sometimes the simplest problems are the most frustrating...
I'm converting from a Mala cab to a Hyperspin cab and so far I am awestruck at how easy it's been. But I'm having a problem getting Nestopia to act right. It works perfectly on it's own, it works perfectly from Mala, but when I run it from Hyperspin, it starts fine but immediately loses focus to Hyperspin. I'm on the NES wheel, select the game, the screen goes black as if the game's starting, then I'm looking at the NES wheel again. Nestopia is running in the background. I can alt-tab to it and it's running fine. I just can't figure out what's making it lose focus.
The command line Mala uses is the plain vanilla "executable.exe rompath" and it works fine in Mala. In Hyperspin I tried both the Hyperlaunch script and just running it with the regular vanilla command line instructions. Both ways, nestopia starts fine but immediately loses focus.
I've been pulling my hair out over this. I can't think of anything running in the background with HS that's not running when I use Mala.
Anybody got any ideas? I can post further details if anybody can suggest what details might be handy.
Thanks
i had this same exact problem and after a ton of help and troubleshooting the only sensible solution was to switch emu's. we determined that it was possibly a specific problem to my cpu,
if your not set on using nestopia i would switch to FCEUX and it will most likely solve the issue.
My HS Progress:
MAME: 100% Daphne:0% Turbo Grafx16: 100% Neo Geo: 100%
Atari2600: 90% Atari5200: 100% Atari7800: 100% Atari Lynx: 100%
NES: 100% SNES: 100% N64: 100% SMS: 100%
Genesis: 100% Sega CD: 10% Dreamcast: 20% Sega 32X: 100%
there is winactivate command in ahk which acts same as alt-tab
check ahk home page
maybe instead of vanilla start of nestopia you can use something like
run ...
sleep ... (or winwait or winwaitactive)
winactivate ...
and maybe:
click (clicks on current mouse position)
I recommend switching to FCEUX as well. I had nothing but problems with Nestopia albeit different problems. Ultimately it boiled down to keeping V-Sync on and dealing with noticeable input lag, or turning V-Sync off and dealing with tremendous screen tear. I switched to FCEUX and haven't looked back since
FCEUX should be the new recommended default NES emulator for Hyperspin. Nestopia really is a cannibal beast that eats itself inside out.
Heh heh!
<em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
  • 5 months later...
Wow, I just had the "no focus" issue and I switched to fceux.
fceux doesnt seem to have any issues so far.
Thanks for input out there fellow HS fans.
  • 2 years later...
Sorry that i had to resurrect this topic but im having the same problem here. And no, using other emulators isn't an option either because i have different problems with them. I just want to use Nestopia, is there any command i could add to the ahk to fix this?
