jcr484 Posted September 13, 2014 Posted September 13, 2014 So I'm, using xpadder and a PS3 controller for my setup and everything seems to be working perfectly except for 1 thing. After I exit a game and go back to the HyperSpin Wheel my controller no longer works. I can use my keyboard to spin the wheel and enter games and my controller takes back over. But once I leave a game the wheel no longer works for my controller. Any help out there? I've been google searching this one for a few days and keep coming up short. Either what Im reading isn't solving it or when a person figures out a fix they just respond with something along the lines of "Fixed it nvm" lol Thanks guys!
albert_c Posted September 13, 2014 Posted September 13, 2014 I have that problem too. I believe what it is is that HyperLaunch is not switching back from your emulator profile to the HyperSpin frontend profile. You would have to post the troubleshooting log for the developer to confirm. But, I think I have found a solution and that is not to use Xpadder at all. Instead, see if ghutch92's newly released Hyperspin Startup Script works with your PS3 controller outright. Download that here and go into HyperLaunch and disable the keymapper functions. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
xagesz Posted September 13, 2014 Posted September 13, 2014 I have mine setup to work so that Xpadder AutoProfile automattically runs my Hyperspin Profile once it pops back to hyperspin. Be warry though that I have issues occasionally when I alt-tab to hyperspin by accident then going back to game. But for normal use its working for me. "Pinball Unknown" - 46/30/DMD - A work in Progress Kick it Harder
albert_c Posted September 13, 2014 Posted September 13, 2014 HyperSpin Startup Script really does wonders. It is probably as close as we will ever get to having joystick navigation integrated into HyperSpin. Resolves these things for me: 1. Xpadder UI flashing briefly as profile is loaded. 2. Profiles intermittently not switching back/to front end/emulator. 3. The need to setup a profile for each emulator; can use emulator's button mappings where available. 4. Focus sometimes not being switched to or from HyperSpin FE to/from emulator. 5. Joystick registry entry where joystick name has trailing space in entry. And it is really really really easy to use. It was designed to work with the X360 controller, but I can confirm that it works with these boards: -Zero Delay Encoder -Zero Delay Rematch/PS3 Encoder -Akishops Custom PS360+ When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
