Problem exiting epsxe emulator pressing ESC
bartmarley
Hi, i am able to load psx roms via HS, but the problem occurs when i press ESC t oquit the game and returning to HS : it does nuthin pressing ESC! I have to alt+f4 but with this manipulation even if i return correctly to HS i still hear the epsxe emulator game running, i have to kill process manually so here are my epsxe configs where is the problem plizz? :
[exe info]
path=F:\HYPERSPIN\Emulators\PSX\epsxe170\
rompath=K:\Games\PSX\ROMS\
userompath=
exe=ePSXe.exe
romextension=bin,cue,iso,ccd,img
parameters=
searchsubfolders=
pcgame=false
winstate=HIDDEN
hyperlaunch=true
; Sony Playstation
; ePSXe v1.7.0
; by Shateredsoul/Brolly/djvj
; 1.1
; epsxe can't deal with bin/cue dumps with more than one audio track if you load the cue file directly.
; For these to work you must mount the cue on daemon tools and let epsxe boot the game from there.
; Extract all your BIOS files to the bios subfolder. Then goto Config->Bios and select the bios you wish to use.
; Go to Config->Video then choose a plugin. Pete's OpenGL line is preffered
; Click Configure (under video plugin) and choose fullscreen and set your desired resolution. Video options/results will vary based on the plugin you choose.
; If you are using images with multiple tracks, set your extension to cue (make sure all your cues are correctly pointing to their tracks).
; Go to Config->Cdrom->Configure button and select the drive letter associated with your daemon tools virtual drive.
If ( romExtension = ".cue" )
RunWait, %daemonToolsPath% -mount 0`, "%romPath%%romName%%romExtension%"
Run, %executable% -nogui, %emuPath%
Else
Run, %executable% -nogui -loadiso "%romPath%%romName%%romExtension%", %emuPath%
Process, WaitClose, %executable%
RunWait, %daemonToolsPath% -unmount 0
ExitApp
CloseProcess:
return
  • 1 month later...
Have you made sure that you properly set up Hyperlaunch 2.0? Check the instructions for install again and see if you missed the step where you setup the exit_emulator_key.
<em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
That's not the 1.1 module you get from HyperList, it is missing the winclose line:
http://hyperlist.hyperspin-fe.com/?module=browseahk&system=135
I just posted about a similar thing here:
http://www.hyperspin-fe.com/forum/showthread.php?t=15453
I will do some updates and put out a v1.2 soon if it there is any problem with the winclose line on there now.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Was playing around with this, no matter what method I try, epsxe always remains running in my process list, using about 25% cpu and just never closes. Even pressing alt+f4 manually. I'm trying not to use process, close, but it seems inevitable right now. I'll fiddle more tonight, but I still prefer pcsxr as it's updated daily.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
No problems for me exiting this emulator. No sign of it running in the process list either.
QRS, do you use Esc as your exit key? After some more testing it seems Escape has to be used to close epsxe. Anything else and the process continues to run, you can hear it, but can't see anything. I've tried winclose and alt+f4, nothing else works except Esc. This is quite buggy and I think the only emu that acts this way. This is a big issue for anyone who uses anything but Escape as their exit key. Even putting Send, {Esc} in the CloseProcess did not work. The emulator only sees it if I press the physical button.
Reading random forums, the correct way to close epsxe is to press Escape. I tried not sending the -nogui parameter so Escape will go back to the menu, then I can do File-Exit really quickly, but it still requires epsxe to acknowledge an esc press via ahk, which it doesn't...
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
ok figured it out, I had to slow down the whole process. I'll have an update up shortly.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Module updated. I'm 90% sure this should work for everyone, no matter what you have your exit key as:
http://hyperlist.hyperspin-fe.com/index.php?module=browseahk&system=135
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Yes, I'm using Escape as my exit key.
Ok, but did you test the new module?
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Well here's the thing, Escape works exiting the emulator from fullscreen outside HS. Have you verified this is the case on your end? I have the CloseProcess set to send Escape instead of your exit key.
You can also try setting a different exit key, and test that.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I was having similar issues with the launcher.ahk ver 2.0.
I reused the code in the nes module by rain and made this playstation module.
changes in red
RunWait, %executable% [color="Red"]-nogui -loadbin[/color] "%romPath%%romName%%romExtension%", %emuPath%, Hide
ExitApp
CloseProcess:
[color="Red"]Process Close, %executable%[/color]
return
result... emulator closes instantly with esc
The only drawback i found...
When an emulator sets a new resolution the previous resolution doesn't get restored upon exit of the emulator.
The only things affected are OS & hyperspin's resolution upon exiting the emulator. only if their resolution is not the same as the emulator you are running last :deal:
I'm using this on a crt and run everything at 640x480 so it works great for my setup.
Process, close is a last resort, do not use it as it does not allow the emu to save anything.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Did you try my latest epsxe module satur09?
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Yes. Currently loads epsxe1.7.0 fine. When I press esc key the emulator doesn't close, screen fades to black in an infinite loop, mouse cant select/click and must ctrl+alt+del to reboot
You can turn off the exit screen, just set that variable to false. You should turn off the loadingscreen too until everything works correctly. When things don't work, always turn those screens off, otherwise they will drive you nuts troubleshooting.
You don't have to reboot either, just end the hyperlaunch.exe process running in task manager.
If you physically press ESC on your keyboard, outside of HS while running epsxe, does it still not close?
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
disabled loadingscreen
disabled exitscreen
now esc has no effect
by default pressing esc in epsxe does close to epsxe gui
pressing esc in cmd epsxe with -nogui command does close to windows
So it works fine outside HS, but not in HS?
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Open your Task Manager, launch epsxe through HS, press Esc on your keyboard, look in Task Manager. Is epsxe.exe still running?
If yes, set your HS exit key to something other then Esc, any other key will work. and Try the above again. Is epsxe.exe still running in task manager?
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Yes it is still running.
Yes it is still running no matter what key I set, it still has no effect.
