Pedestal controls with hyperspin
JFlash3785
I can get the joystick and buttons working in the games but not on the hyperspin wheel itself. Need help pls :afraid::stupid::banghead::banghead:
Can anyone help me?
The hyperspin wheel controls I think are automatically set to a standard layout (arrow keys move the wheel up and down, enter chooses a game and esc key exits a menu). To change these:
-open up HyperHQ.exe. Its in the Hyperspin main folder.
-click on the Controls tab
-click on "set" for whichever control(s) you want to change and press the physical arcade button that you want to correspond with it
-close out of HyperHQ and it should work.
I had a funny problem with my controls where they weren't working until I plugged in my computer speakers. That might be it too. Good luck!
I forgot to mention that under the Control tab in HyperHQ, I was on the Keyboard tab. The Joystick, Trackball, and Spinner tabs are all disabled on my setup because I don't have them in my machine. Everything is mapped to keyboard buttons through an ipac. Not sure if you're running a similar setup
I'm running a different board, not an ipac. It's a bit better response time than an ipac for fighting games when I compared the two. It shows up as a joystick controller when you plug it in.
I will try what you mention and get back to you, thank you
HyperSpin only works with keyboard / ipac etc, not with anything that shows up as a joystick in Windows. Check the link in my sig for known bugs.
the board once plugged in shows up as Xin-Mo DUal Arcade under devices.
Tried all above and nothing working. The games and during the games work great, just can't control the hyperspin wheels :(
Try this startup script with built in joystick / joypad support:
http://www.hyperspin-fe.com/forum/showthread.php?t=28986
