SORHP Posted October 10, 2014 Posted October 10, 2014 Windows xp keeps breaking resolution as windows is loading... Any help??? Need for it to set and hold My Arcade Machines...
albert_c Posted October 10, 2014 Posted October 10, 2014 What resolution do you need to keep it at? If you need to keep it at 640x480, you can hold F8 after the POST screen and select VGA mode. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
SORHP Posted October 10, 2014 Author Posted October 10, 2014 Yes, I do need 640x480, but I don't want to have to keep a keyboard plugged in, the system is setup. But sometimes windows changes the Rez , and it brings it out of sync with the monitor . I'm using an arcade vga card, and a wg k 7000 25" monitor My Arcade Machines...
albert_c Posted October 10, 2014 Posted October 10, 2014 Plug the keyboard in and hold down F8 after the post screen. Select VGA mode. You will only have to do it the one time. After that, it should boot to 640x480 everytime. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
SORHP Posted October 10, 2014 Author Posted October 10, 2014 Thank you guys! I'll try it out My Arcade Machines...
