Hyperspin not loading into Mame but HyperLaunch works
tagbone
I'm sure this is probably an easy fix. I can get th roms to load fin in RocketLauncher, however when I select MAME from Hyperspin it doesn't populate anything. I have the rom path set up in HyperHQ for the Mame wheel. Do I need to set something as the executable?
Being a bit more specific. I launch hyperspin and hit enter on Mame, it reloads Mame but never goes into the roms I have.
From within hyperlaunchhq my roms populate into the audit correctly and boot from there as well.
first make sure mame is pointing to your roms folder 2nd make sure mame runs and has the right module also turn off fade etc so you can see an error otherwise check the log
sig.png 100%
