philongames Posted October 22, 2014 Posted October 22, 2014 When launching FreeDO in Hyperspin, I receive an error saying that I'm missing a config file, and should launch FreeDO manually to generate one. Problem is that FreeDO doesn't appear to be creating any config file when launching FreeDO by itself. Anyone else run into this issue when setting up FreeDO in Hyperspin?
rfancella Posted October 22, 2014 Posted October 22, 2014 When launching FreeDO in Hyperspin, I receive an error saying that I'm missing a config file, and should launch FreeDO manually to generate one. Problem is that FreeDO doesn't appear to be creating any config file when launching FreeDO by itself. Anyone else run into this issue when setting up FreeDO in Hyperspin? As per the module notes. See this post: http://www.hyperspin-fe.com/forum/showthread.php?6272-New-FreeDO-version-2-1a&p=58411#post58411 Ignore the reference to the HyperLaunch.ahk script. You are just concerned with the config file. Thanks, Ron PS: I think I had to create both the xml file on my setup. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
sonicboom88 Posted October 22, 2014 Posted October 22, 2014 I use FourDo, better control setting try that?. Hyper Helper Ready To Help
philongames Posted October 23, 2014 Author Posted October 23, 2014 Thanks for the help guys! I tried messing with FreeDO, but continue to have problems with it (I'm not as smart as the modules I think...). I switched to FourDO and everything is working perfectly. Much easier to set up in HyperSpin!
sonicboom88 Posted October 23, 2014 Posted October 23, 2014 I like it easy controls FreeDo is really hard to set controls. Hyper Helper Ready To Help
