monkeychunkuk Posted October 27, 2014 Posted October 27, 2014 Hey I wonder if anyone can help In my stupidity I tried to save cash and bought this little usb interface for my latest builds Here's my problem I've set it up to navigate the menus but when I start a game ( mame for example ) I can't exit back to the wheel do I need set my exit button ( butting 10 ) in each emulator ? Is that even possible ? Any one used one of these ? Sent from the smut hut
albert_c Posted October 28, 2014 Posted October 28, 2014 In HLHQ under Global Settings>(I think under settings?), there is an 'Exit Emulator' function that you can map button inputs to (you can map a combination of buttons). Then set all your systems/emulators to 'Use Global' (they should be this way by default). Then anytime you input those button combinations, it will exit out your emulator back to the HyperSpin UI. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
monkeychunkuk Posted October 28, 2014 Author Posted October 28, 2014 Thank you I ve found mane lets me set the exit key Sent from the smut hut
monkeychunkuk Posted November 4, 2014 Author Posted November 4, 2014 Ok now I have problem exiting fusion emulator Does anyone know a way to config the exit button for it? Sent from the smut hut
monkeychunkuk Posted November 5, 2014 Author Posted November 5, 2014 Hmm anyone? Sent from the smut hut
