kega fusion exit key change
dasaint80
Hey all,
I'm trying to make "3" not "numberpad3" my exit button for most, but especially for fusion, emulators. I've changed the "exit_emulator_key=" to 3 and i'm still not able to exit with "3" is there anything else I have to do to the modules or the individual ini settings?
Thanks
Steve
Use "Numpad3" instead of "3".
<em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
My apologies. I read your post backwards. Technically, just writing "exit_emulator_key=3" should work. There's no other way to define it for HyperLaunch.
No. You don't need to modify modules or HyperLaunch.ahk at all. And NEVER compile. If you changed them or compiled them, then I suggest you re-download them.
You add that line to "Settings.ini" located at: (...Hyperspin\Settings\).
What's your module script like?
In mine I have at the bottom:
CloseProcess:
Process, Close, %Executable%
Return
Which basically shuts down the emulator (like ALT-F4) when you press your hotkey
That's not even close to the same as Alt+F4. You never want to use process, close if you don;t have to. It doesn't allow sram or high score saving.
Please use my module which uses:
CloseProcess:
FadeOutStart()
WinClose, Fusion ahk_class KegaClass
Return
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
CloseProcess:
FadeOutStart()
Return
This worked for me!!! thanks so much!!!!
  • 1 year later...
thank you very much the(CloseProcess:
FadeOutStart()
Return
work great.
  • 1 year later...
Hello, I have the same problem. But where and how do i need to change the script ? thanks for the help
edit: i added the rule "exit_emulator_key='" to the settings.ini file
And then edit the module HyperSpin\HyperLaunch\Modules\Fusion and at
CloseProcess:
FadeOutStart()
Return
at the end
but fusion still not closes via key ' (tried other keys as wel)
What am i doing wrong ?
