shredder Posted November 24, 2014 Posted November 24, 2014 Ok, I'm usually more of a forum reader than an a poster, But I am calling in reinforcements on this one. Full Story: I have been running HL 2.0 for the longest time and upgraded to HL 3 with also using HLHQ Managed to get everything working except for the scummvm emulator which loads all games just fine; however, it does not load the correct resolution to see and play the game. AT BEST I can get it to a full screen setting with a black boarder around it. My video settings are configured through HDMI to an HDTV that runs at a 1920x 1080 resolution.... But back to the issue. I have tried coming at this with every angle I can think of including (but not limited too) adjusting the module. Adjusting module settings, changing desktop resolution. Nothing seems to help. The issue seems to be with the emulator itself and not within hyperspin, but with that said, if I am within hyperspin and launch a Scummvm game, Then return to hyperspin, Resolution settings are not restored from whatever resolution it bounces too when the Scummvm Emulator is launched. I will happy to post a log file upon request, if someone lets me know the proper format to submit it.
alexminasepm Posted November 24, 2014 Posted November 24, 2014 Ok, I'm usually more of a forum reader than an a poster, But I am calling in reinforcements on this one. Full Story: I have been running HL 2.0 for the longest time and upgraded to HL 3 with also using HLHQ Managed to get everything working except for the scummvm emulator which loads all games just fine; however, it does not load the correct resolution to see and play the game. AT BEST I can get it to a full screen setting with a black boarder around it. My video settings are configured through HDMI to an HDTV that runs at a 1920x 1080 resolution.... But back to the issue. I have tried coming at this with every angle I can think of including (but not limited too) adjusting the module. Adjusting module settings, changing desktop resolution. Nothing seems to help. The issue seems to be with the emulator itself and not within hyperspin, but with that said, if I am within hyperspin and launch a Scummvm game, Then return to hyperspin, Resolution settings are not restored from whatever resolution it bounces too when the Scummvm Emulator is launched. I will happy to post a log file upon request, if someone lets me know the proper format to submit it. Are you using bezel? Using any graphic filter in scumm? I had a resolution problem using filter plus bezel. Turned off bezel and worked fine.
shredder Posted November 27, 2014 Author Posted November 27, 2014 I am not using a bezel and I am not using a graphic filter. I have tried turning different graphic rendering settings on and off and filters on and off. I have also tried to select and deselect full screen mode within the scummvm emulator itself with no change in results. Resolution settings seem to appear at random and this occurs even outside of hyperspin.
