NIVO Posted October 7, 2012 Posted October 7, 2012 from a fellow ohioan, nice work on the guns there frosty moderator B.Y.O.A.C. http://www.arcadecontrols.com
Drakin Posted October 7, 2012 Posted October 7, 2012 Nice hanger for the guns...I'm gonna have to copy that...hope you don't mind:) 1. Make sure your leds are pointing at the gun. 2. Make sure your aimtrak pcb eye can see your leds and clear the upper lip of the gun barrel. Then you just shoot each arrow when it stops in the left corner right corner and center bottom. 3. If it does not register still try standing closer/further 4. Still no go make sure your lighting around you is not too bright 5. Also some may need to be manually calibrated through the F2 service menu.
bigtater Posted July 6, 2014 Posted July 6, 2014 What size bit did you use to counterbore the holes on the sides and do you think it has caused any issues? Sweet looking cabinet!
