SORHP Posted December 3, 2014 Posted December 3, 2014 This may seem simple, but I'm lost. I have an LEDwiz connected to 2 buttons, I need those 2 buttons to light up orange, and orange only. How can I accomplish this without buying an app? Thank you guys! My Arcade Machines...
maxxsinner Posted December 9, 2014 Posted December 9, 2014 Hey Sorhp. Need a bit more info and maybe some pics to help us help you mate. Are the buttons fitted with just an orange LED? Are they 12 volt rated (resistor already in place) or is it something you put together yourself? If its something you put together yourself, have you got the spec sheet on the LED so we can do some calculations on resistor size needed? You may not need the LEDwiz to control this LED at all if I am reading your OP correctly. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
