Hyperspin Update from 1.2.0
celestial
Hi guys, :hello:
im kinda new to this forum and Hyperspin in general,
i actually have Hyperspin 1.2.0 and HyperLaunch 1.1.9.0 installed, (almost) everything is running smootlywith hypersplash too,
now i use the frontend on a pc, but soon im gonna build a "mame"cab, so ill change the controller, from keyboard to joystick and stuff.
I would like also to add some steam games,and from what i understeand, my actual version of HS, doesnt allow me to install pclauncher, (correct me if im wrong)
Is there a safe way to follow,in order to update HS and HL without risk of loose settings etc.?
Once i will have installed HyperlaunchHQ is everything (eg. Settinings, emulators) allready there, or i do have to manually set everything?
I've tryed to search in this forum and im sure you allready talked about this in past, i just can't find something similar to my situation, if you remember some thread please just paste it.
Thanks in advance for your help.
Sorry for my poor english/typos.
Ormai hypersin si limita a fare da interfaccia grafica, il lancio di giochi/emulatori viene fatto tutto con gli script di hyperlaunch. Se non erro esiste un modulo dedicato a steam.
Per i settaggi intendi quelli degli emulatori? Quelli rimangono uguali, puoi usare i profili di xpadder da hyperlaunch ma puoi anche utilizzare i profili automatici di xpadder. Per i percorsi alle cartelle degli emulatori e delle roms le devi ridare nuovamente all'interno del programma di settaggio di hyperlaunch. Ti conviene installare hyperspin in una nuova cartella e cominciare a prenderci confidenza ;)
