Need a little help with FreeDO
stillcore
Hi,
I recently decided to build a new MAME machine and wanted to add 3DO to the systems list. I'm using my old external hard drive that I set up about 4 yeas ago with (what I believe is) the 1st hyperlaunch on it from years ago.
I have every system that I want running perfectly except for the 3DO. I was wondering if anyone could take a look at my logs and perhaps help me figure out my issue.
I have hyperlaunch starting up the FreeDO 2.1 Alpha emulator in hyperspin, fullscreen, and can exit with the commands, however, it won't load the ISO. It's going to the main emulator screen and saying "insert game disc"
There's obviously an error somewhere with my script and it pointing to the correct iso paths, but I can't figure it out.
Any help would be greatly appreciated. This is driving me nuts.
Thanks, so much, in advance.
My hyperlaunch ahk:
;***********************************Pana*sonic 3DO Test2.1*******************************
else if (systemName = "Panasonic 3DO" && executable = "FreeDO.exe")
hideDesktop()
SetWorkingDir, %emuPath%
Hotkey, %exitEmulatorKey%, CloseProcess
Gui +AlwaysOnTop -Caption +ToolWindow
Gui, color, 0
Gui Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%,
FileDelete, %emupath%config.xml
FileCopy, %emupath%restore.xml, %emupath%config.xml
Run, "%EmuPath%%Executable%", Hide UseErrorLevel
sleep, 500
WinWait, FreeDO v.2.1 Alpha ~ FPS 60`, INTFPS 60,
IfWinNotActive, FreeDO v.2.1 Alpha ~ FPS 60`, INTFPS 60, , WinActivate, FreeDO v.2.1 Alpha ~ FPS 60`, INTFPS 60,
WinWaitActive, FreeDO v.2.1 Alpha ~ FPS 60`, INTFPS 60,
Send, {ALTDOWN}{ALTUP}{up}{ENTER} ;{ENTER}
WinWait, Open,
IfWinNotActive, Open, , WinActivate, Open,
WinWaitActive, Open,
sleep, 500
clipboard=
clipboard=%romPath%%romName%%romExtensio*n%
ClipWait
Sleep,100
Send,^v
Sleep,100
send, {ENTER}
Sleep, 100
send, {F11}
sleep,500
send, {F9}
sleep, 2000
Gui Destroy
Process, WaitClose, %executable%
WinActivate, HyperSpin
FreeDO cfg:
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Generated by A... config library (ACL) v.1.5. Copyright © Grishin Maxim Leonidovich, April 2008 (http://altmer.arts-union.ru). Library is free only for free projects. -->
<!-- Used TinyXML. Original code (2.0 and earlier )copyright © 2000-2006 Lee Thomason (www.grinninglizard.com) -->
<root>
<ARM>
<Francy type="int" val="40000000" />
</ARM>
<Emulate>
<MultyTreaded type="bool" val="false" />
</Emulate>
<Sound>
<Volume type="int" val="62" />
<Velosity type="int" val="100" />
<Xchenge type="bool" val="true" />
</Sound>
<Video>
<AspectControl type="bool" val="false" />
<VSynk type="bool" val="false" />
<HighRes type="bool" val="false" />
<Filter type="int" val="0" />
</Video>
<roms>
<bios type="string" val="C:\Users\Greg\Desktop\Hyperspin\Emulators\Panasonic 3DO\FZ10.bin" />
</roms>
<cdrom>
<iso type="string" val="C:\Users\Greg\Desktop\Hyperspin\Emulators\Panasonic 3DO\roms\Another World (1994)(Interplay)(EU)[!]" />
</cdrom>
<pbus>
<devices type="string" val="Joy,Mouse">
<Joy type="string" val="p,a,a,vkDown,vkUp,vkRight,vkLeft,vkZ,vkX,vkC,vkEnter,vkSpace,vkD,vkA,a,a" />
<Mouse type="string" val="a,p,a,a,p,a,a,p,ml,mm,mr,vkQ,mym31,mym8,mym7,mym6,mym5,mym4,mym3,mym2,mym1,mym0,mxm31,mxm8,mxm7,mxm6,mxm5,mxm4,mxm3,mxm2,mxm1,mxm0" />
</devices>
</pbus>
</root>
Hyperspin logo:
06:17:15 PM | HyperSpin Started
06:17:15 PM | Going FullScreen
06:17:15 PM | Checking for updates
06:17:15 PM | Update Check Complete
06:17:15 PM | Startup program: HyperSpin.exe
06:17:15 PM | Startup params not set
06:17:15 PM | Working directory: D:\Hyperspin\
06:17:15 PM | Window State: HIDDEN
06:17:15 PM | Launching HyperSpin.exe
06:17:15 PM | Command Line is HyperSpin.exe
06:17:15 PM | Playing intro video
06:17:16 PM | Error intializing joysticks
06:17:16 PM | Menu Mode is multi
06:17:16 PM | Loading Main Menu.xml
06:17:16 PM | Main Menu.xml successfully loaded
06:17:17 PM | Main Menu wheel loaded successfully
06:17:18 PM | Loading Panasonic 3DO.xml
06:17:18 PM | roms_only is true, checking files
06:17:18 PM | Main Menu.xml successfully loaded
06:17:19 PM | Panasonic 3DO wheel loaded successfully
06:17:19 PM | Launching Game
06:17:19 PM | Using HyperLaunch
06:17:19 PM | Getting HyperLaunch path
06:17:19 PM | HyperLaunch located at HyperLaunch.exe
06:17:19 PM | Running HyperLaunch.exe
06:17:19 PM | HyperLaunch Command Line is: HyperLaunch.exe "Panasonic 3DO" "Another World (1994)(Interplay)(EU)[!]"
06:17:39 PM | Loading Main Menu.xml
06:17:39 PM | Main Menu.xml successfully loaded
06:17:39 PM | Main Menu wheel loaded successfully
06:17:41 PM | Exit program unavailable
06:17:41 PM | Quiting Hyperspin
06:17:41 PM | Bye!
Hi,
That does look like the old HyperLaunch setup.
You may have some trouble getting help with it. It is like trying to get support for Windows 95. ;)
Most issues with the old modules have been cleared and cleaned up with RocketLauncher.
Thanks,
Ron
I have it working, but you'd need to be using the original HL1, too. If you are I'll send you my settings so you can mirror them to yours.
I'm going to eventually rebuild mine with RL and replace what I have, I just like being a dork and figuring out the old way to do it.
