Cannot Find HyperLaunch.exe?
Somsai
When I tested it with HyperLaunch the game started up just fine, but when I try it on HyperSpin it gives me the error, "Cannot Find HyperLaunch.exe".
Here is my settings.ini
[Main]
Menu_Mode=single
Single_Mode_Name = MAME
Enable_Exit_Menu = true
Enable_Exit = true
Version = 0.8.0.0
Last_System=MAME
[Resolution]
FullScreen = true
Width = 1024
Height = 768
ColorDepth = 32
Refreshrate = 0
DirectDraw = true
[backgrounds]
Animated = true
UseAdvanced = true
[introVideo]
Use_Intro = true
Stop_On_Keypress = true
[sound]
Master_Volume = 100
Video_Volume = 100
[AttractMode]
Active = true
Time=600
MaxSpinTime = 10
HyperSpin = true
[Keyboard]
Key_Delay = false
[P1 Controls]
Start=49
Exit=51
Up=104
Down = 98
SkipUp=100
SkipDown=102
SkipUpNumber=16
SkipDownNumber=90
HyperSpin=17
Genre=67
Favorites=53
[P2 Controls]
Start=50
Exit=52
Up=82
Down=70
SkipUp=68
SkipDown=71
SkipUpNumber=87
SkipDownNumber=69
HyperSpin=65
Genre=221
Favorites=54
[P1 Joystick]
Joy = 0
Threshold = 40
Up=
Down = Analog_Down
SkipUp = Analog_Left
SkipDown = Analog_Right
Enabled=false
[P2 Joystick]
Joy = 1
Threshold = 40
Up = Analog_Up
Down = Analog_Down
[Trackball]
Enabled = true
Sensitivity = 95
[spinner]
Enabled = true
Sensitivity = 95
[startup Program]
Executable =
Paramaters =
Working_Directory =
WinState = HIDDEN
[Exit Program]
Executable =
Paramaters =
Working_Directory =
WinState = NORMAL
[LEDBlinky]
Active = false
Path =
[HiScore]
Active=true
Y = 550
Delay = 1
[Optimizer]
Quality=LOW
CPU_Priority=high
Your mode is set to single mode which may be a problem and may be why there is no mention of the Hyperlaunch path.
Are you just running Mame? If so there is no need for Hyperlaunch unless you want the Hyperlaunch extra features.
I'm just trying to get AT LEAST Mame to work. It worked before, but when I upgraded my HyperSpin (Been like 2 years)
it stopped working, but yeah I just started using Hyperlaunch today and seemed simple enough.
I'll let you know if running it w/o HL will work.
EDIT:
It works if I launch it normally, but doesn't work with HL. I'm going to see if the HL works for my other emulators.
Okay, I couldn't get it to work on my N64 w/ HyperLaunch. It gave me the same error as before. Not sure what I'm doing wrong.
My old Project64 was old so I dowloaded the new one and same outcome.
Going to try if downgrading to Project64 2.0 will work.
Here is my Settngs ini
[Main]
[b][color="#FF0000"][color="#FF0000"][color="#FF0000"]Menu_Mode=multi[/color][/color][/color][/b]
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Sega Saturn
[b][color="#FF0000"]Hyperlaunch_Path=O:\HyperLaunch\[/color][/b]
[Resolution]
FullScreen=true
Width=1024
Height=768
Scanlines_Active=false
Scanlines_Image=aperture1x2rb_ag
Scanlines_Scale=1
Scanlines_Alpha=0.1
[Optimizer]
CPU_Priority=high
Quality=BEST
Image_Smoothing=true
Animated_Backgrounds=false
Inter_Backgrounds=false
Level1_Backgrounds=true
Level2_Backgrounds=true
Level3_Backgrounds=true
Level4_Backgrounds=true
Special_Backgrounds=true
Wait_For_Special=true
Animated_Artworks=true
Level1_Artworks=true
Level2_Artworks=true
[introVideo]
Use_Intro=true
Stop_On_Keypress=true
[sound]
Master_Volume=80
Video_Volume=60
Wheel_Volume=30
Interface_Volume=63
[AttractMode]
Active=true
Time=120
MaxSpinTime=4
HyperSpin=true
Wait_For_Video=false
[Keyboard]
Key_Delay=true
[P1 Controls]
Start=13
Exit=66
Up=38
Down=40
SkipUp=37
SkipDown=39
SkipUpNumber=70
SkipDownNumber=86
HyperSpin=32
Genre=48
Favorites=76
[P2 Controls]
Start=69
Exit=81
Up=87
Down=83
SkipUp=65
SkipDown=68
SkipUpNumber=74
SkipDownNumber=77
HyperSpin=88
Genre=72
Favorites=90
[P1 Joystick]
Enabled=false
Joy=0
Threshold=100
Start=Button_1
Exit=Button_2
Up=POV_Up
Down=POV_Down
SkipUp=POV_Left
SkipDown=POV_Right
SkipUpNumber=Button_3
SkipDownNumber=Button_4
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[P2 Joystick]
Enabled=false
Joy=1
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
SkipDown=Analog_Right
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[Trackball]
Enabled=false
Sensitivity=50
[spinner]
Enabled=false
Sensitivity=90
[startup Program]
Executable=HS Startup.exe
Paramaters=
Working_Directory=O:\
WinState=NORMAL
[Exit Program]
Executable=Randomizer.exe
Paramaters=1
Working_Directory=O:\APPS\Randomizer\
WinState=NORMAL
[LEDBlinky]
Active=true
Path=O:\HyperSpeech\
[HiScore]
Active=true
Y=550
Delay=2
Have you followed any guides for using the new Hyperlaunch?
If you are using multiple systems, make sure multi is selected.
And Execution is set to Hyperlaunch.
I figured out what happened. That error was caused because my HS was outdated/wrong.
I overwrote things and I think I got confused while trying to upgrade.
So I retraced my steps and reinstalled.
I just kept my Database, HyperLaunch,and Media settings.
Since I already updated my Database.
Thanks for trying to help though gigapig. :)
