Theme Question
dsnyd22
I have a pretty simple issue, i just cant find the right setting to change it. My theme art is blocking my wheel art on a few themes. Most of my themes automatically fade out when you start turning the wheel. I need to know how to change this so my theme art is not blocking the wheel??
A lot of themes overlap the wheel, all themes should fade out except for their background when spinning the wheel though...
yeah that is the problem. Its Sega Model 2 Emulator. Sonic covers the wheel and doesnt fade out. So when you spin the wheel you cant see the name of the rom.
On a specific theme or with a default theme?
^capital extensions as well^
Isn't there an option in hypertheme on the artwork somewhere to check "behind wheel" ? Seems like I had this issue with a theme I was editing recently, and that did the trick for my artwork.
yeah i thought there was, and i feel like i used it years ago, just cant remember where. I ended up downloading another theme for the same system to eliminate the simple problem. Id like to know if this option does exist or not however.
