Configuration Wizard in KAT5200 keeps saying its my first time running
nguerra
Hi everyone. I'm not sure if the settings file isn't being saved but every time I start KAT5200 I get the Configuration Wizard. All of the settings I originally added are gone and the Wizard is saying this is the first use of KAT5200. Is there a save somewhere or are these settings remembered when I exit? I'm using KAT5200 0.6.2 and running Vista 32 bit.
Are you saving a profile every time you make a change? If so you could try setting the "kat5200.db3" file as Read Only (right click and go to properties) but only do that if your creating the profile correctly or saving it as the default.
I deleted the kat5200.db3 file and the log then started Kat5200 and it didn't ask to run the wizard, so this is a bit strange.
Have you also put the bios in a folder and pointed to it?
I just tried to look for the kat5200.db3 file and after a windows search I don't see it. Any idea where it would be located on a Vista system?
