Hyperlaunch HQ super Acan help
jedfactor
Ive been trying to set up the Super Acan, in hyperlaunch hq, I don't get any options under default emulator, and the MESS module won't show when I set the default emulator to MESS.
Anyone know why this is?
Thanks
You probably haven't set up MESS as a global emulator yet. The module - both the beta and the previous ones - had the Super Acan in it. Make sure your system name matches the one in the module as well.
I have MESS working with other systems so must be the name is not matching, how do I go about getting the name to match correctly?
Thanks
maybe the games are not launching because i don't have the superacan bios for MESS, the module not showing up in hyperhq wouldn't stop the games from launching would it?
I don't think it has a BIOS, actually.
  jeremy0203 said:
I bet you named it "Super Acan" didn't you? It should be named "Funtech Super Acan"
Ive named it Funtech Super A'can, how can I change the name? so I need to simply rename the media folders? or do I need to delete the system in hyper hq and start again?
changed it and im getting the module showing up in hyperhq now, but games won't launch, it does say in the mess module notes that it needs a bios.
0.154, checked other systems in MESS, and none of them are working now, seems its a problem with MESS.
pretty sure it was working before.
going to download it now, think something else is up though, as none of my mess systems are launching in hyperlaunch got an error message about error: call to non existent function, specifically set key delay 50.
Are you using all the updated modules from the latest HyperLaunch?
Pretty sure I am used the module updater yesterday. Can I re download the MESS module from anywhere? think I must have done something to it by accident.
If you haven't already updated to the latest HyperLaunch beta, you cannot use the module updater. You must update from GIT. That is also how you would get an updated/redownloaded MESS module.
Thanks, nearly had a panic attack then.
Mess is still not working, it seems it is trying to launch MAME insted for some reason I dont understand, and now MAME isn't launching as it is saying that cheats are enabled but I don't have the zip file. what the hell.
Got MAME working ok now, its strange with MESS though, some systems work, and some don't. But I have no idea why the ones that don't work aren't working as they are set up the same.
I get an ahk error related to MAME, very strange.
