ALIE Posted January 1, 2015 Posted January 1, 2015 i find getting a new look very confusion:hmmmm2:. for example is this http://www.hyperspin-fe.com/forum/showthread.php?11742-mega-drive-theme only for the mega drive?. i wanted at least for starters, something that changed everything and wasn't a specific system.
gigapig Posted January 1, 2015 Posted January 1, 2015 If you require something more unified then check this thread out, you will require ftp access however. If I have misunderstood, please elaborate. www.hyperspin-fe.com/forum/showthread.php?33008-Unified-Megatheme-Extended
ALIE Posted January 2, 2015 Author Posted January 2, 2015 No I'm just trying understand how I use themes, where to get them, Like I wanna change the whole look, like some of the ones on YouTube. But I can't make them myself. And I'm sorry maybe you did answer, but I can't access the page.
gigapig Posted January 2, 2015 Posted January 2, 2015 Understood, and the link I posted was for gold members only. So your options are the downloads section which has a limited amount of themes etc. To get access to more themes you will need to become a Gold or Platinum member. Gold gets you access to the ftp for manual download of artwork and access to gold member areas of the forum. Platinum will get you the above but also the use of Hypersync, with that you can set up the Hypersync software to keep all your artwork in sync and up to date. Membership to Emumovies is separate but once a platinum member of Hyperspin you can use a discount code to get 25% off Emumovies membership. All of that is for media only. I hope that answers your query.
ALIE Posted January 2, 2015 Author Posted January 2, 2015 ok i got access. is there a guide how to use it
gigapig Posted January 2, 2015 Posted January 2, 2015 You can try this, it's a bit old but should be relavent. If you get stuck just ask. http://www.hyperspin-fe.com/forum/showthread.php?26101-HyperSync-3-5-Consumer-Release-Download-Now!
ALIE Posted January 3, 2015 Author Posted January 3, 2015 thanks gonna try when Emu is up and running again.
