Apple IIGS and ActiveGS module
spudgunjake
I have tried to get the module to work, with some games running fine.
Had to altar the module to run with Apple IIGS,
If (SystemName = "Apple IIGS") {
if (romExtension = ".dsk") {
bootslot := "6"
SlotNumber := "6"
} Else {
bootslot := "5"
SlotNumber := "5"
} Else {
bootslot := "5"
SlotNumber := "5"
But I can't get the multi games to swap drives, I have spent some part of the Xmas break trying to get it work for I have to ask for help.
Has any one got the or part of the Apple IIGS.ini file they could send me,
Example adventure land (Disk 1 of 2) needs a disk to be swapped from s6d2 to d6d1 after the first disk loads, but cant see how to set this up.
[Adventureland (Disk 1 of 2)]
SingleDrive=false
HardDiskImage=false
External_OS=false
DiskSwapDrive=2
Best regards JOHN.
bootslot := "6"
SlotNumber := "6"
} Else {
bootslot := "5"
SlotNumber := "5"
} Else {
bootslot := "5"
SlotNumber := "5"
SingleDrive=false
HardDiskImage=false
External_OS=false
DiskSwapDrive=2
Best regards JOHN.
John,
The new beta version of HyperLaunch contains a full ActiveGS module. It will load up to four disk images on boot. ;)
Thanks,
Ron
Hi Ron, thanks for the link,
Done all the updates, But the ActiveGS module looks the same.
if I may ask a question. the part that isn't working is the multigame section, am I right in saying to swap a disk we use the num - key to swap disks, I have set the multi game option in hyperlaunchhq
MultiGame:
If (SystemName = "Apple II" || "Apple IIGS")
DriveToChoose := If DiskSwapDrive = "1" ? "S6D1" : "S6D2"
Else
DriveToChoose := If DiskSwapDrive = "1" ? "S5D1" : "S5D2"
MultiGame:
Else
Ahhh... I see what you are trying to do now.
So, does the game boot to Disk 2 of 2?
Give this a try. Tell it to use only one drive.
Change to SingleDrive=true
When asked to change disks, hit your HyperPause key and change to Disk 2.
Hope this helps,
Thanks,
Ron
I have downloaded then beta version looks really nice, look forward to using it once I have tested everything, multigame seem to be working fine to a point.
just like to say big thank you for all the advice.
best regards john.
  • 2 years later...
Is there any tutorial to make ActiveGS run? Actually i followed the "not so clear" instructions and i can't get any game working.
