iceman1981 Posted January 28, 2015 Posted January 28, 2015 i am using the dragon's lair dvd iso, works straight from daphne loader, when i try to run it in hyperlaunch i'm getting the error below. is there on option in hyperlaunchHQ that i need to modify to get this game to run? fatal error! unknown argument c:\emulators\daphne\roms\lair.zip here is the daphne log --DAPHNE version 1.0.12 --Command line is: daphne.exe lair vldp -framefile C:/Emulators/Daphne/vldp_dl/lair/lair.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir C:\Emulators\Daphne -bank 0 11111001 -bank 1 00100111 -sound_buffer 2048 -x 640 -y 480 --CPU : GenuineIntel 3450 MHz || Mem : 4032 megs --OS : Windows XP/.NET || Video : ATI Radeon HD 4800 Series --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting alternate home dir: C:\Emulators\Daphne Setting sound buffer size to 2048 Setting screen width to 640 Setting screen height to 480 Set 640x480 at 32 bpp with flags: 0 Initializing sound system ... GI Sound chip initialized at 2000000 Hz No joysticks detected Remapping input ... Loading compressed ROM image dl_f2_u1.bin...8192 bytes read. Loading compressed ROM image dl_f2_u2.bin...8192 bytes read. Loading compressed ROM image dl_f2_u3.bin...8192 bytes read. Loading compressed ROM image dl_f2_u4.bin...8192 bytes read. Framefile parse succeeded. Video/Audio directory is: C:/Emulators/Daphne/vldp_dl/lair/./ YUV overlay is done in software (ie unaccelerated). Booting ROM ... Play LDP : disc is already playing, play command ignored Play Display disable received Search to 323 received - [25] Attract Mode, Sequence 0 Attract Mode search succeeded d0 Play Freeing memory used to store audio stream... Shutting down sound system... Shutting down video display...
rfancella Posted January 28, 2015 Posted January 28, 2015 i am using the dragon's lair dvd iso, works straight from daphne loader, when i try to run it in hyperlaunch i'm getting the error below. is there on option in hyperlaunchHQ that i need to modify to get this game to run? fatal error! unknown argument c:\emulators\daphne\roms\lair.zip here is the daphne log --DAPHNE version 1.0.12 --Command line is: daphne.exe lair vldp -framefile C:/Emulators/Daphne/vldp_dl/lair/lair.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir C:\Emulators\Daphne -bank 0 11111001 -bank 1 00100111 -sound_buffer 2048 -x 640 -y 480 --CPU : GenuineIntel 3450 MHz || Mem : 4032 megs --OS : Windows XP/.NET || Video : ATI Radeon HD 4800 Series --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting alternate home dir: C:\Emulators\Daphne Setting sound buffer size to 2048 Setting screen width to 640 Setting screen height to 480 Set 640x480 at 32 bpp with flags: 0 Initializing sound system ... GI Sound chip initialized at 2000000 Hz No joysticks detected Remapping input ... Loading compressed ROM image dl_f2_u1.bin...8192 bytes read. Loading compressed ROM image dl_f2_u2.bin...8192 bytes read. Loading compressed ROM image dl_f2_u3.bin...8192 bytes read. Loading compressed ROM image dl_f2_u4.bin...8192 bytes read. Framefile parse succeeded. Video/Audio directory is: C:/Emulators/Daphne/vldp_dl/lair/./ YUV overlay is done in software (ie unaccelerated). Booting ROM ... Play LDP : disc is already playing, play command ignored Play Display disable received Search to 323 received - [25] Attract Mode, Sequence 0 Attract Mode search succeeded d0 Play Freeing memory used to store audio stream... Shutting down sound system... Shutting down video display... Hmmm.. The Daphne log looks good. Where is the error appearing? Can you provide a screen shot of it or in the least, post your HyperLaunch log? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
iceman1981 Posted January 28, 2015 Author Posted January 28, 2015 21:16:36:681 | HL | INFO | +N/A | Main - HyperLaunch v3.1.0.3 BETA (www.hyperlaunch.net) 21:16:37:421 | HL | INFO | +733 | Main - System Specs: HyperLaunch Dir: C:\Hyperspin\HyperLaunch HyperLaunch is: 32-bit OS: Microsoft Windows 7 Ultimate SKU: Ultimate Total Memory: 4039.95 MB Free Memory: 2205.28 MB Used Memory: 1834.672 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: ATI Radeon HD 4800 Series GPU 1 RAM: 1024.00 MB GPU 1 Driver Version: 8.632.1.2000 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: Realtek High Definition Audio Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1440 Current AHK Desktop Height: 900 AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 21:16:37:421 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 21:16:37:421 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists 21:16:37:421 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists 21:16:37:421 | HL | INFO | +0 | GetSystems - Started 21:16:37:421 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\HyperLaunchHQ\Databases\Systems.xml exists 21:16:37:421 | HL | INFO | +0 | GetSystems - Found a HyperLaunch Systems.xml: "C:\Hyperspin\HyperLaunch\HyperLaunchHQ\Databases\Systems.xml" 21:16:37:461 | HL | INFO | +47 | GetSystems - Ended 21:16:37:471 | HL | INFO | +0 | Main - HyperLaunch launched directly 21:16:43:261 | HL | INFO | +5803 | Main - HyperLaunchHQ.exe coordinates are x200 y200 w200 h200 21:16:43:261 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Plugins\HyperLaunchHQ.plugin exists 21:16:43:261 | HL | INFO | +0 | Main - Loading Front End Plugin: "HyperLaunchHQ" 21:16:43:261 | HL | INFO | +0 | Main - HyperLaunch received "Daphne" and "lair" 21:16:43:271 | HL | INFO | +0 | Main - lair is using the default emulator: Daphne 21:16:43:271 | HL | INFO | +0 | Main - Checking for a [Daphne] section in C:\Hyperspin\HyperLaunch\Settings\Daphne\Emulators.ini 21:16:43:271 | HL | INFO | +0 | Main - Found [Daphne] in C:\Hyperspin\HyperLaunch\Settings\Daphne\Emulators.ini 21:16:43:271 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Modules\Daphne\Daphne.ahk exists 21:16:43:281 | HL | INFO | +16 | Main - CRC Check - CRC matches, this is an official unedited module. 21:16:43:281 | HL | INFO | +0 | Main - lair will use module: C:\Hyperspin\HyperLaunch\Modules\Daphne\Daphne.ahk 21:16:43:291 | HL | INFO | +0 | Main - Did not find a "C:\Hyperspin\HyperLaunch\Settings\Daphne\Game Options.ini" file, skipping any game-specific options. 21:16:43:291 | HL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 21:16:43:291 | HL | INFO | +0 | Main - INI Keys read 21:16:43:291 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 21:16:43:291 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 21:16:43:291 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\FontReg.exe exists 21:16:43:311 | HL | INFO | +31 | Main - "lair" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 21:16:43:311 | HL | INFO | +0 | CheckPaths - Started 21:16:43:311 | HL | INFO | +0 | CheckPaths - Found rom: C:\Emulators\Daphne\roms\lair.zip 21:16:43:311 | HL | INFO | +0 | CheckPaths - Ended 21:16:43:321 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 0 pluginPath = C:\Hyperspin\HyperLaunch\Plugins pluginName = HyperLaunchHQ pluginExt = .plugin hlMode = hlTitle = HyperLaunch hlVersion = 3.1.0.3 BETA hlAuthor = djvj hlURL = www.hyperlaunch.net langFile = C:\Hyperspin\HyperLaunch\Data\Language\Localization.ini frontendPID = 15268 frontendPath = C:\Hyperspin\HyperLaunch\HyperLaunchHQ frontendExe = HyperLaunchHQ.exe frontendExt = exe frontendName = HyperLaunchHQ frontendDrive = C: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = C:\Emulators\Daphne\DaphneLoader.exe emuPath = C:\Emulators\Daphne emuName = Daphne emuExt = exe romPath = C:\Emulators\Daphne\roms romPathFromIni = C:\Emulators\Daphne\roms romExtension = .zip romExtensionOrig = .zip romExtensions = zip executable = DaphneLoader.exe systemName = Daphne dbPath = dbName = lair dbExt = romName = lair romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = C:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = C:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 3 logShowDebugConsole = false logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false hlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1440 originalHeight = 900 dtEnabled = true dtPath = C:\Program Files (x86)\DAEMON Tools Ultra\DTLauncher.exe dtUseSCSI = true dtAddDrive = true servoStikEnabled = false ledblinkyEnabled = false ledblinkyFullPath = ledblinkyProfilePath = C:\Hyperspin\HyperLaunch\Profiles\LEDBlinky ledblinkyHLProfile = C:\Hyperspin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch emuIdleShutdown = 0 launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig== hideCursor = false hideEmu = false hideFE = false fadeIn = true fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = true fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeXScale = fadeYScale = fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Layer 2 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = C:\Hyperspin\HyperLaunch\Data HLMediaPath = C:\Hyperspin\HyperLaunch\Media HLErrSoundPath = C:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = C:\Hyperspin\HyperLaunch\Modules moduleFullName = C:\Hyperspin\HyperLaunch\Modules\Daphne\Daphne.ahk moduleName = Daphne modulePath = C:\Hyperspin\HyperLaunch\Modules\Daphne moduleExtension = ahk moduleExtensionsPath = C:\Hyperspin\HyperLaunch\Module Extensions libPath = C:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\mame\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgXScale = 1 mgYScale = 1 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 mgCandidate = mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = C:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = C:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = C:\Hyperspin\HyperLaunch\Profiles\xpadder keymapperFrontEndProfileName = HyperLaunchHQ keymapperFrontEndProfile = false keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunchHQ defaultProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default systemProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne xPadderSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne\_Default emuProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne\Daphne romProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Daphne\lair HyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunch blankProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank ahkFEProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunchHQ ahkDefaultProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\_Default ahkSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Daphne ahkEmuProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Daphne\Daphne ahkRomProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Daphne\lair ahkHyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = C:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = C:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe mon1O = 0 pacDrivedllFile = C:\Hyperspin\HyperLaunch\Module Extensions\PacDrive32.dll 21:16:43:321 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 21:16:43:321 | HL | INFO | +0 | BuildScript - Loaded Fade Init.ahk scripts 21:16:43:321 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 21:16:43:321 | HL | WARNING | +0 | BuildScript - "C:\Hyperspin\HyperLaunch\Lib\User Functions Init.ahk" not found 21:16:43:321 | HL | INFO | +0 | BuildScript - Validating module 21:16:43:321 | HL | INFO | +0 | BuildScript - Validation complete 21:16:43:321 | HL | INFO | +0 | BuildScript - Module: MEmu = Daphne MEmuV = v1.0.13 MURL = http://www.daphne-emu.com/ MAuthor = djvj MVersion = 2.0.6 MCRC = F8545233 iCRC = 7FCE1920 MID = 635038268879753802 MSystem = "Daphne","LaserDisc" ;---------------------------------------------------------------------------- ; Notes: ; Executable should be Daphne.exe NOT Daphneloader.exe ; You need the module's ini from GIT, remove the (Example) from the filename. It has settings for each game so they work properly. ; If you want to define custom controls for each game, follow this process: ; 1) Manually run DaphneLoader.exe ; 2) Select each game you want to configure and click the Configure button. Select the Input tab and define your controls and hit OK and repeat for each game. ; 3) Create a folder in your emu directory called "controls" and copy your current dapinput.ini into it. This will be your default controls used for all games that a custom one was not created. ; 4) Launch each game you defined controls for through DaphneLoader. DaphneLoader will set your custom controls in the dapinput.ini. Now exit the game. ; 5) After each game you launch, copy the dapinput.ini into the controls folder and name it after the rom name you use in your xml: Example: lair.ini ; ; First time users, please follow the guide found @ http://www.hyperspin-fe.com/forum/showthread.php?29410-Complete-Guide-for-Daphne-in-HyperSpin-and-RL ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" globalParams := IniReadCheck(settingsFile,"settings","globalParams","vldp -blank_searches -prefer_samples -noissues -fastboot",,1) fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) screenWidth := IniReadCheck(settingsFile, "Settings", "ScreenWidth",A_ScreenWidth,,1) screenHeight := IniReadCheck(settingsFile, "Settings", "ScreenHeight",A_ScreenHeight,,1) pauseOnExit := IniReadCheck(settingsFile,"settings","pauseOnExit","false",,1) hwAccel := IniReadCheck(settingsFile,"settings","hwAccel","true",,1) min_seek_delay := IniReadCheck(settingsFile,romName,"min_seek_delay",A_Space,,1) seek_frames_per_ms := IniReadCheck(settingsFile,romName,"seek_frames_per_ms",A_Space,,1) homedir := IniReadCheck(settingsFile,romName,"homedir",".",,1) bank0 := IniReadCheck(settingsFile,romName,"bank0",A_Space,,1) bank1 := IniReadCheck(settingsFile,romName,"bank1",A_Space,,1) bank2 := IniReadCheck(settingsFile,romName,"bank2",A_Space,,1) bank3 := IniReadCheck(settingsFile,romName,"bank3",A_Space,,1) sound_buffer := IniReadCheck(settingsFile,romName,"sound_buffer",A_Space,,1) params := IniReadCheck(settingsFile,romName,"params",A_Space,,1) version := IniReadCheck(settingsFile,romName,"version",romName,,1) frameFile = %romName% ; storing parent romName to send as the framefile name so we don't send wrong name when using an alternate version of a game BezelStart() fullscreen := If fullscreen = "true" ? " -fullscreen" : "" If bezelPath ; this variable is only filled if bezel is enabled and a valid bezel image is found { params:= params . " -ignore_aspect_ratio" screenWidth := " -x " . Round(bezelScreenWidth) ;bezelScreenWidth variable is defined on the BezelStart function and it gives the desired width that your game screen should have while using this bezel screenHeight := " -y " . Round(bezelScreenHeight) ;idem above } Else { screenWidth := " -x " . screenWidth screenHeight := " -y " . screenHeight } min_seek_delay := If min_seek_delay ? " -min_seek_delay " . min_seek_delay : "" seek_frames_per_ms := If seek_frames_per_ms ? " -seek_frames_per_ms " . seek_frames_per_ms : "" homedir := If homedir ? " -homedir " . homedir : "" bank0 := If bank0 ? " -bank 0 " . bank0 : "" bank1 := If bank1 ? " -bank 1 " . bank1 : "" bank2 := If bank2 ? " -bank 2 " . bank2 : "" bank3 := If bank3 ? " -bank 3 " . bank3 : "" sound_buffer := If sound_buffer ? " -sound_buffer " . sound_buffer : "" hwAccel := If hwAccel = "true" ? " -opengl" : " -nohwaccel" params := globalParams . " " . params hideEmuObj := Object("ahk_class SDL_app",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, 7zExtractPath) ; If you have alternate controls for a specific game, this will overwrite the current dapinput.ini with your custom one romControlIni := emuPath . "\controls\" . romName . ".ini" defaultControlIni := emuPath . "\controls\dapinput.ini" daphneControlIni := emuPath . "\dapinput.ini" If FileExist(romControlIni) { ; if a romName control ini exists Log("Module - Found a romName input ini and will overwrite the existing dapinput.ini: " . romControlIni) FileCopy, %romControlIni%, %daphneControlIni%, 1 ; copy rom dapinput, overwriting working one } Else If FileExist(defaultControlIni) { ; if a default control ini exists Log("Module - No romName input ini found, overwriting the current dapinput.ini with a default one: " . defaultControlIni) FileCopy, %defaultControlIni%, %daphneControlIni%, 1 ; copy default dapinput, overwriting working one in case a rom one was set from previous launch } Else Log("Module - No romName or default inis found, leaving the current dapinput.ini alone") ; If launched game is an alternate version of a parent, this will send the alternate's name to daphne. romName = %version% HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait ; This allows us to send variables, that when empty, are not sent to the Run command ; msgbox % executable . A_Space . romName . A_Space . params . fullscreen . screenWidth . screenHeight . min_seek_delay . seek_frames_per_ms . homedir . bank0 . bank1 . bank2 . bank3 . sound_buffer . " -framefile """ . romPath . "\" . frameFile . romExtension . """" Run(executable . A_Space . romName . A_Space . params . hwAccel . fullscreen . screenWidth . screenHeight . min_seek_delay . seek_frames_per_ms . homedir . bank0 . bank1 . bank2 . bank3 . sound_buffer . " -framefile """ . romPath . "\" . frameFile . romExtension . """", emuPath) WinWait("ahk_class SDL_app") WinWaitActive("ahk_class SDL_app") BezelDraw() HideEmuEnd() FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() HaltEmu: Send, {P} Return RestoreEmu: Winrestore, AHK_class %EmulatorClass% Send, {P} Return CloseProcess: FadeOutStart() BezelExit() If pauseOnExit = true { Send, {P} Sleep, 100 } WinClose("ahk_class SDL_app") Return 21:16:43:321 | HL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 21:16:43:321 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 21:16:43:321 | HL | WARNING | +0 | BuildScript - "C:\Hyperspin\HyperLaunch\Lib\User Functions.ahk" not found 21:16:43:321 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 21:16:43:321 | HL | INFO | +0 | Main - Module is built 21:16:43:321 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 21:16:43:321 | HL | INFO | +0 | Main - Running module
iceman1981 Posted January 28, 2015 Author Posted January 28, 2015 ok saw an issue, I was linked to daphneloader.exe, changed to daphne.exe and it opened but got a file parsing error --DAPHNE version 1.0.12 --Command line is: C:\Emulators\Daphne\daphne.exe lair vldp -blank_searches -prefer_samples -noissues -fastboot -opengl -fullscreen -x 1440 -y 900 -homedir . -framefile C:\Emulators\Daphne\roms\lair.zip --CPU : GenuineIntel 3500 MHz || Mem : 4032 megs --OS : Windows XP/.NET || Video : ATI Radeon HD 4800 Series --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting alternate home dir: . Setting screen width to 1440 Setting screen height to 900 WARNING : You have specified an abnormal screen resolution! Normal screen resolutions are: 640 x 480 800 x 600 1024 x 768 1280 x 960 1280 x 1024 1600 x 1200 Set 1440x900 at 32 bpp with flags: 80000002 Initializing sound system ... GI Sound chip initialized at 2000000 Hz No joysticks detected Remapping input ... Loading compressed ROM image dl_f2_u1.bin...8192 bytes read. Loading compressed ROM image dl_f2_u2.bin...8192 bytes read. Loading compressed ROM image dl_f2_u3.bin...8192 bytes read. Loading compressed ROM image dl_f2_u4.bin...8192 bytes read. Framefile Parse Error Framefile only has 1 line in it. Framefiles must have at least 2 lines in it. Mpeg Path : PK ---BEGIN FRAMEFILE CONTENTS--- PK ---END FRAMEFILE CONTENTS--- Could not initialize laserdisc player! Shutting down sound system... Shutting down video display...
rfancella Posted January 28, 2015 Posted January 28, 2015 ok saw an issue, I was linked to daphneloader.exe, changed to daphne.exe and it opened but got a file parsing error ...snipped... Ok, here is your issue. You have your rom path pointed to the Daphne Roms. It should be pointed to your framefile directory or your A/V directory. --Command line is: C:\Emulators\Daphne\daphne.exe lair vldp -blank_searches -prefer_samples -noissues -fastboot -opengl -fullscreen -x 1440 -y 900 -homedir . -framefile C:\Emulators\Daphne\roms\lair.zip The framefile is not the lair.zip, it should be lair.txt. Also, Yes, thank you Jeremy. Please post logs, any logs, inside code tags. To learn how to use them, see here: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thanks, Ron PS: I also have a Daphne guide here: http://www.hyperspin-fe.com/forum/showthread.php?29410-Complete-Guide-for-Daphne-in-HyperSpin-and-RL Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
