exiting sega genesis
jon
hi all i have a small problem exiting fusion, no matter what key i have set to exit the emulation via hyperlaunchhq the only key to exit back to hyperspin that works is the esc key.
if i launch the emulator in hyperlaunch my chosen key exits no problem
any ideas
many thanks
jon
if im playing a game using the fusion emulator and i want to exit back to hyperspin to play another game i have to use the esc key
i have set hyperlaunchhq to exit using my xbox button which works no problem and what i want it to do
the problem is when im using hyperspin
does that make sense?
  • 2 months later...
I would leave fusion behind and start using Retroarch if I were you.
why would you leave fusion alone??? Its a very good emulator. Is Retroarch any better and why?
[sIGPIC][/sIGPIC]
Retoarcs primary benefit is different options on look like shading, color, arcade look etc. It has lots of options to play with but I don't think it emulates any better since its a platform that borrows cored from other emulators. Think of it as a hub for many emulators and u can adjust the visual settings. Does it emulate better? Probably no but can you make the game look more like the original in terms of look? Probably yes
