Need advice for making my Hyperspin system faster
BlueGoblin
Hi All,
I currently run a 3.0ghz intel CPU G860 w/8gb ram running windows 7 64bit.
My system is running very slow when booting up the hyperspin machine and sometimes when manuvering through the hyperspin menus its slow and on occasion the controls dont work. This pretty much occurs when booting up Hyperspin.
What can I do to boost things up to make my system better? Any advice is appreciated. Look below at the attached jpg.
If your system is running good other then hyperspin being slow, I would recommended a better gfx card. Are you using onboard video or a dedicated Graphics card? Are you running hyperspin from your main HDD? or off USB?
its running off the main HDD... i have the ASUS P8H61-I LX R2.0 w/ Radeon HD 6450
How full is your HDD? sometimes if its really full like less then 1gb left you will get some slow downs related to the paging file. I still have no idea what would cause the controls to not respond unless your CPU usage is at 100% or something.
RexRyan - you were right! I had many apps open up via start up menu. I disabled them and it made a big difference. Thank you for pointing that out to me.
JoeyJojo - My HDD is 2tb and I have about 600mb used.
I would also suggest maybe looking into an SSD drive. I just setup a Samsung 850 Pro SSD in a machine today. It takes 15 seconds from completely shutdown to Hyperspin running as I have it booting at start up.
Here it is:
Tapatalked from my Note 3
+1 on the SSD :)
