badwhip Posted February 16, 2015 Posted February 16, 2015 Very first time setting up a hyperspin system. I have hyperspin installed along with hyperlaunch and hyperlaunchhq. my first emulator is for nintendo 64 emulator is project 62 2.1.1 emultator plays fine in hyperlaunch. does not load in hyperspin after fixing a few errors it say something about a . before the rom. I have a log file. 02:05:00 PM | HyperSpin Started 02:05:00 PM | Going windowed mode 02:05:00 PM | Checking for updates 02:05:00 PM | Update Check Complete 02:05:00 PM | Startup program unavailable 02:05:00 PM | Playing intro video 02:05:18 PM | Error intializing joysticks 02:05:18 PM | Menu Mode is single 02:05:18 PM | Loading Nintendo 64.xml 02:05:18 PM | Nintendo 64.xml successfully loaded 02:05:19 PM | Nintendo 64 wheel loaded successfully 02:06:09 PM | Launching Game 02:06:09 PM | Using HyperLaunch 02:06:09 PM | Getting HyperLaunch path 02:06:10 PM | HyperLaunch located at H:\Hyperspin\HyperLaunch.exe 02:06:10 PM | Running HyperLaunch.exe 02:06:10 PM | HyperLaunch Command Line is: H:\Hyperspin\HyperLaunch.exe "Nintendo 64" "007 - GoldenEye (USA)" 02:07:15 PM | Launching Game 02:07:16 PM | Using HyperLaunch 02:07:16 PM | Getting HyperLaunch path 02:07:16 PM | HyperLaunch located at H:\Hyperspin\HyperLaunch.exe 02:07:16 PM | Running HyperLaunch.exe 02:07:16 PM | HyperLaunch Command Line is: H:\Hyperspin\HyperLaunch.exe "Nintendo 64" "All-Star Baseball 2000 (USA)" 02:07:25 PM | Exit program unavailable 02:07:25 PM | Quiting Hyperspin 02:07:25 PM | Bye!
showstopper Posted February 16, 2015 Posted February 16, 2015 Think you are using the old hyoerlaunch? Do you have a hyoerlaunch folder? If so take out the hyperlaunch from c:\hyperspin and try launch hlhq. It should ask you where your HL is, point it tobc:\hyperspin\hyperlaunch How to update HyperLaunch
badwhip Posted February 16, 2015 Author Posted February 16, 2015 it has a hyperlaunch folder in the dir hyperspin when i hit that folder i have a hyperlaunch.exe with other folders as such Daemon,data,HyperLaunchHq,lib,media,module extensions modules,plugins,profiles,settings, the hyperlaunchhq folder has the following filesdatabases,lib,media,notes,plugins,profiles,settings and a hyperlaunhq.exe so you are saying i dont need the other hyperlaunchexe and folders? if that is correct do i just have a hyperlaunch folder with contents of hperlaunchhq? i am instslling on a passport drive and i changed the ini files to refect that.
rexryan Posted February 16, 2015 Posted February 16, 2015 if you have team viewer pm me and i can help.
