tobes4k Posted February 18, 2015 Posted February 18, 2015 I've been trawling the forums and haven't been able to find someone with the same issue... I've setup HyperLaunchHQ and XPadder as per various different guides but I cant get it right. When hyperspin launches it does not select the correct profile, when a game is launched (znesw) it quits out of Xpadder and does not relaunch it when the game closes. In the Keymapper / Global, I have a HyperLaunch, HyperSpin, Blank and _Default profile (which I pinched off someone offering a solution to someone else also having problems) and they all open and test fine from within HyperLaunchHQ. Under general settings I have Xpadder path setup, Frontend Profile Name HyperSpin, Frontend Profile xpadder, Enable Hyperlaunch Profile Under Settings / Global I have Keymapper enabled, Keymapper xpadder rest default. I have renamed the folders in the profiles.zip to match my controllers title: "Controller (XBOX 360 For Windows"). Any help would be greatly appreciated. Profiles.zip log.txt Xpadderini.txt
gigapig Posted February 19, 2015 Posted February 19, 2015 Why bother using it at all, just set the controls in the emulator and use ghutchs' Startup Script to run HS. http://www.hyperspin-fe.com/forum/showthread.php?28986-HyperSpin-Startup-Script
Fromlostdays Posted February 19, 2015 Posted February 19, 2015 As bleak as it is, I agree with Giga. I gave up on xpadder. Startup script plus retroarch/emulator in game control set up = forget keymapping. Sorry I can't be more help. Walter:beerglass:
