strawdog Posted February 19, 2015 Posted February 19, 2015 I have been building my Hs drive on an external hard drive on a win 7pc, i have now got my cabinet pc (win 8.1) I have copied the contents of the drive over to the new pc, changed drive name etc. HSHQ works fine. But if i try to run HS i hear intro music for a second and then nothing. The first time this happened Win 8 popped a window asking how i wanted to run xpadder files, i set the path to xpadder.exe - it did not continue load HS. Now when i try to run HS i hear the first second of the intro music and then nothing, just stays on the desktop. do i need to alter something in my start up script? [Required] HyperSpin_Folder_Path=P:\HyperSpin HyperLaunch_Folder_Path=P:\HyperSpin\HyperLaunch [General] Primary_Color_RRGGBB=363636 Secondary_Color_RRGGBB=ffffff [Controls] Joysticks_Enabled=False Joysticks_MaxNumberOfJoysticks=4 Joystick_Delay=225 Joystick_Deadzone=25 Joystick_Up=JoyY-|JoyPOVN Joystick_Down=JoyY+|JoyPOVS Joystick_SkipUp=JoyX-|JoyPOVW Joystick_SkipDown=JoyX+|JoyPOVE Joystick_SkipUpNumber=Joy5 Joystick_SkipDownNumber=Joy6 Joystick_HyperSpin=JoyZ-|JoyZ+|Joy9 Joystick_Genre=Joy3 Joystick_Favorites=Joy4 Joystick_Start=Joy1|Joy8 Joystick_Exit=Joy2 Joystick_Roulette=Joy7 Joystick_Volume=JoyR- Joystick_Volume_Close=JoyR+ Joystick_QuickLaunch=JoyU+ Joystick_QuickLaunch_Close=JoyU- Joystick_Info=JoyU- Joystick_Info_Close=JoyU+ Joystick_Filters=JoyR+ Joystick_Filters_Close=JoyR- [startup] Minimize_Background_Windows_Enabled=false Window_Classes_To_Not_Minimize=Shell_TrayWnd,Button Process_Name_To_Close_1= Program_To_Run_Target_1=P:\HyperSpin\Xpadder\p1.xpadderprofile Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= [Exit] Restore_Windows_On_Exit=True Process_Name_To_Close_1= Program_To_Run_Target_1= Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= [Roulette] Roulette_Key=~1 Roulette_Min_MilliSeconds=3000 Roulette_Max_MilliSeconds=8000 [Volume_Menu] Volume_Menu_Key=~2 Volume_Bar_Offset_From_Bottom=44 [QuickLaunch] QuickLaunch_Key=~3 QuickLaunch_Enabled=true QuickLaunch_Left_Offset=5 QuickLaunch_Top_Offset=10 QuickLaunch_Bottom_Offset=10 Item_1_Path= Item_1_Parameters= Item_1_LogoPath= Item_1_Ignore_Process_Close=false
SIMPLYAUSTIN Posted February 19, 2015 Posted February 19, 2015 Ensure that hlhq knows where the xpadder .exe is. Also ensure all of your profiles etc moves over safely with the switch . You Mau have to play with xpadder a lil as it doesn't like cut and past profiles ... It tends to loose them Simply Austin's YouTube
strawdog Posted February 19, 2015 Author Posted February 19, 2015 Ensure that hlhq knows where the xpadder .exe is. Also ensure all of your profiles etc moves over safely with the switch . You Mau have to play with xpadder a lil as it doesn't like cut and past profiles ... It tends to loose them thanks, the HLHQ xpadder path is set, xpadder is working within HLHQ, i can test profiles etc. Just cant get HS to launch. Can i disable xpadder and start HS without, then maybe reinstall xpadder after? -can i get a 'clean' hyperspin start up script.ini from someone maybe? i'll try that
strawdog Posted February 19, 2015 Author Posted February 19, 2015 sorry for another post but thought i should include my hyperlaunch.log http://pastebin.com/uRra5g3H also hyperspin log is this {code} 12:47:28 PM | HyperSpin Started 12:47:28 PM | Going FullScreen 12:47:28 PM | Checking for updates 12:47:28 PM | Update Check Complete 12:47:28 PM | Startup program: HyperSpin Startup Script.exe 12:47:28 PM | Startup params not set 12:47:28 PM | Working directory: P:\HyperSpin\Utilities\ 12:47:28 PM | Window State: NORMAL 12:47:28 PM | Launching HyperSpin Startup Script.exe 12:47:28 PM | Command Line is HyperSpin Startup Script.exe 12:47:28 PM | Playing intro video ALSO- now cleaned up xpadder, configured new controller file and when i boot HS, the Xpadder window pops up - is this causing the issue? how do i resolve? Please help, going nuts here, got a cabinet just sitting here and now no damn HS !?! lol
strawdog Posted February 20, 2015 Author Posted February 20, 2015 SOLVED. I reformatted the drive and did a clean install, all runs fine now. As Austin suggested - Xpadder profiles do not like cutting n pasting.
SIMPLYAUSTIN Posted February 20, 2015 Posted February 20, 2015 Glad I could help I had issues with mine after an upgrade of HLHQ. If Xpadders still popping up, go into settings and change the boot up setting to taskbar only etc. Have fun! Simply Austin's YouTube
strawdog Posted February 20, 2015 Author Posted February 20, 2015 Glad I could help I had issues with mine after an upgrade of HLHQ. If Xpadders still popping up, go into settings and change the boot up setting to taskbar only etc.Have fun! thanks for the tip, Now i have to re map all controls for all emus as i'm plugging it into the cabinet controller today. one day i may actually get to play some games..........maybe
