Emulators Randomly Stop Loading
JayDog
When in using Hyperspin for an extended period of time my emulators will stop loading altogether and the problem won't fix until I restart my computer. I've found that this Is due to Hyperlaunch not properly closing on emulator exits so I manually close it but the problem persists until restart. This happened before I changed which buttons close emulators through controls of HyperlaunchHQ which are Start + Select on any controller being used. So I'm stuck, any suggestions on why this is happening?
Yeah, I close the correct process usually it doesn't help anything until I restart my computer. Its a real inconvenience when I have friends over that have no clue why I have to restart my computer in the middle of playing games haha
This is still continuing to happened everytime I use hyperspin, it seems that I have a harder time getting the emulator to begin to run through the FE. It's been taking 3-4 restarts before I get my emulators to run for a little bit. Any thoughts? About to turn to the hyperspin gods for help haha
*Edit: I should probably check through my logs to see what the hangup first is, I will report back if i solve the problem or get bogged down even more.
The ONLY reason I can think of that something won't launch is when there is a process open (either the emu, and it won't let you run two instances, or the hyperlaunch process.) Makes no sense to have to restart your computer multiple times to get it to launch.
But yes, let us know your set up (are you using hyperlaunch, which version etc) and post your logs.
Walter:beerglass:
Ok I restarted my computer, had emulators working again and also had it break on me again so I could get these logs.
16:44:41:812 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.4 BETA (www.hyperlaunch.net)
16:44:41:946 | HL |     INFO  | +124   | Main - System Specs:
				HyperLaunch Dir: C:\HyperSpin\HyperLaunch
				HyperLaunch is: 32-bit
				OS: Microsoft Windows 7 Ultimate
				SKU: Ultimate
				Total Memory: 8190.49 MB
				Free Memory: 6191.31 MB
				Used Memory: 1999.180 MB
				SystemType: 64-bit
				Physical Processors: 1
				Logical Processors: 4
				GPU 1 Name: NVIDIA GeForce GTX 560 Ti
				GPU 1 RAM: 1024.00 MB
				GPU 1 Driver Version: 9.18.13.4752
				Sound 1 Device: Realtek High Definition Audio
				Sound 1 Status: Enabled
				Sound 2 Device: NVIDIA High Definition Audio
				Sound 2 Status: Enabled
				Sound 3 Device: NVIDIA High Definition Audio
				Sound 3 Status: Enabled
				Sound 4 Device: NVIDIA High Definition Audio
				Sound 4 Status: Enabled
				Sound 5 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
				Sound 5 Status: Enabled
				Sound 6 Device: NVIDIA High Definition Audio
				Sound 6 Status: Enabled
				OS Admin Status: Yes
				Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1080 work)
				Monitor #2 (\\.\DISPLAY2): 0x1080 (0x1080 work)
				Monitor #1 Orientation: Landscape
				Current AHK Desktop Width: 1920
				Current AHK Desktop Height: 1080
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
16:44:41:946 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
16:44:41:947 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
16:44:41:948 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
16:44:41:949 | HL |  WARNING  | +0     | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-f <PATH_TO_MY_FE\FRONTEND.exe>"
16:44:41:950 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x448 y156 w1024 h768
16:44:41:951 | HL |  WARNING  | +0     | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-p <PLUGINTYPE>"
16:44:41:951 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Plugins\HyperSpin.plugin exists
16:44:41:951 | HL |     INFO  | +0     | Main - HyperLaunch received "Nintendo Entertainment System" and "RoadBlasters (USA)"
16:44:41:959 | HL |     INFO  | +16    | Main - RoadBlasters (USA) is using the default emulator: Fceux
16:44:41:959 | HL |     INFO  | +0     | Main - Checking for a [Fceux] section in C:\HyperSpin\HyperLaunch\Settings\Nintendo Entertainment System\Emulators.ini
16:44:41:959 | HL |     INFO  | +0     | Main - Checking for a [Fceux] section in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
16:44:41:959 | HL |     INFO  | +0     | Main - Found [Fceux] in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
16:44:41:960 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Modules\Fceux\Fceux.ahk exists
16:44:41:967 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
16:44:41:967 | HL |     INFO  | +0     | Main - RoadBlasters (USA) will use module: C:\HyperSpin\HyperLaunch\Modules\Fceux\Fceux.ahk
16:44:41:982 | HL |     INFO  | +16    | Main - Did not find a "C:\HyperSpin\HyperLaunch\Settings\Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options.
16:44:41:982 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
16:44:41:984 | HL |     INFO  | +15    | Main - INI Keys read
16:44:41:984 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
16:44:41:985 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
16:44:41:986 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\FontReg.exe exists
16:44:41:991 | HL |     INFO  | +0     | Main - "RoadBlasters (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
16:44:41:991 | HL |     INFO  | +0     | CheckPaths - Started
16:44:41:991 | HL |     INFO  | +0     | CheckPaths - Found rom: C:\Users\Jason\Desktop\NES Roms\RoadBlasters (USA).nes
16:44:41:991 | HL |     INFO  | +0     | CheckPaths - Ended
16:44:41:992 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				pluginPath = C:\HyperSpin\HyperLaunch\Plugins
				pluginName = HyperSpin
				pluginExt = .plugin
				hlMode =
				hlTitle = HyperLaunch
				hlVersion = 3.1.0.4 BETA
				hlAuthor = djvj
				hlURL = www.hyperlaunch.net
				langFile = C:\HyperSpin\HyperLaunch\Data\Language\Localization.ini
				frontendPID = 6484
				frontendPath = C:\HyperSpin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = C:
				exitEmulatorKey = 4joy9&4joy10|5joy9&5joy10|1joy9&1joy10|2joy9&2joy10|6joy7&6joy8|3joy7&3joy8|7joy7&7joy8|9joy7&9joy8|8joy7&8joy8
				exitEmulatorKeyWait = 0
				forceHoldKey = ~esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = C:\HyperSpin\Emulators\Fceux\Fceux-r2699\fceux.exe
				emuPath = C:\HyperSpin\Emulators\Fceux\Fceux-r2699
				emuName = Fceux
				emuExt = exe
				romPath = C:\Users\Jason\Desktop\NES Roms
				romPathFromIni = C:\Users\Jason\Desktop\NES Roms
				romExtension = .nes
				romExtensionOrig = .nes
				romExtensions = 7z|zip|nes
				executable = fceux.exe
				systemName = Nintendo Entertainment System
				dbPath =
				dbName = RoadBlasters (USA)
				dbExt =
				romName = RoadBlasters (USA)
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 400
				romMappingMenuMargin = 65
				romMappingTextMargin = 15
				romMappingMenuFlagWidth = 55
				altArchiveNameOnly =
				altRomNameOnly =
				altArchiveAndRomName =
				altArchiveAndManyRomNames =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = false
				blockInputTime = 0
				blockInputFile = C:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				lockLaunch = false
				lockLaunchGame =
				screenRotationAngle = 0
				screenRotationAngleGame =
				logFile = C:\HyperSpin\HyperLaunch\HyperLaunch.log
				logLevel = 3
				logShowDebugConsole = false
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				hlDebugConsoleStdout =
				sysType = 64-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = false
				dtPath =
				dtUseSCSI = false
				dtAddDrive = true
				servoStikEnabled = false
				ledblinkyEnabled = false
				ledblinkyFullPath =
				ledblinkyProfilePath = C:\HyperSpin\HyperLaunch\Profiles\LEDBlinky
				ledblinkyHLProfile = C:\HyperSpin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeMuteEmulator = false
				fadeUseBackgrounds = false
				fadeWidthBaseRes = 1920
				fadeHeightBaseRes = 1080
				fadeLyr1Color = FF000000
				fadeLyr2X = 0
				fadeLyr2Y = 0
				fadeLyr2W =
				fadeLyr2H =
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 450
				fadeLyr3Y = 450
				fadeLyr3W =
				fadeLyr3H =
				fadeLyr3Adjust = 0.8
				fadeLyr3PicPad = 0
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3StaticX = 0
				fadeLyr3StaticY = 870|1575
				fadeLyr3StaticW =
				fadeLyr3StaticH =
				fadeLyr3StaticAdjust = 1
				fadeLyr3StaticPicPad = 0
				fadeLyr4Adjust = 1
				fadeLyr4X = 1792|952
				fadeLyr4Y = 891|1596
				fadeLyr4W = 128
				fadeLyr4H =
				fadeLyr4Pos = No Alignment
				fadeLyr4FPS = 50
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = Image
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 900
				fadeBarWindowH = 180
				fadeBarWindowR = 30
				fadeBarWindowM = 30
				fadeBarWindowHatchStyle = 8
				fadeBar = 7zOnly
				fadeBarNon7zProgressTime = 0
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 30
				fadeBarR = 10
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 8
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 150
				fadeRomInfoSystemName = image
				fadeRomInfoManufacturer = text with label
				fadeRomInfoGenre = disabled
				fadeRomInfoRating = image
				fadeRomInfoTextMargin = 7
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeText3 = Loading Game
				fadeText4 = Loading Complete
				fadeFont = Arial
				fadeExtractionTime = disabled
				fadeExtractionTimeTextX = 0
				fadeExtractionTimeTextY = 0
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = C:\HyperSpin\HyperLaunch\Media\Fade
				HLDataPath = C:\HyperSpin\HyperLaunch\Data
				HLMediaPath = C:\HyperSpin\HyperLaunch\Media
				HLErrSoundPath = C:\HyperSpin\HyperLaunch\Media\Sounds\Error
				modulesPath = C:\HyperSpin\HyperLaunch\Modules
				moduleFullName = C:\HyperSpin\HyperLaunch\Modules\Fceux\Fceux.ahk
				moduleName = Fceux
				modulePath = C:\HyperSpin\HyperLaunch\Modules\Fceux
				moduleExtension = ahk
				moduleExtensionsPath = C:\HyperSpin\HyperLaunch\Module Extensions
				libPath = C:\HyperSpin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = C:\HyperSpin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = C:\HyperSpin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\Users\Jason\AppData\Local\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgWidthBaseRes = 1920
				mgHeightBaseRes = 1080
				mgYOffset = 500|800
				mgFont = Arial
				mgText2Offset = 100
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = true
				hpKey = NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = C:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {1 down}{1 up}{I down}{I up}|{2 down}{2 up}{I down}{I up}|{3 down}{3 up}{I down}{I up}|{4 down}{4 up}{I down}{I up}|{5 down}{5 up}{I down}{I up}|{6 down}{6 up}{I down}{I up}|{7 down}{7 up}{I down}{I up}|{8 down}{8 up}{I down}{I up}|{9 down}{9 up}{I down}{I up}|{0 down}{0 up}{I down}{I up}
				hpLoadStateKeyCodes = {1 down}{1 up}{P down}{P up}|{2 down}{2 up}{P down}{P up}|{3 down}{3 up}{P down}{P up}|{4 down}{4 up}{P down}{P up}|{5 down}{5 up}{P down}{P up}|{6 down}{6 up}{P down}{P up}|{7 down}{7 up}{P down}{P up}|{8 down}{8 up}{P down}{P up}|{9 down}{9 up}{P down}{P up}|{0 down}{0 up}{P down}{P up}
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper = xpadder
				xpadderFullPath = C:\HyperSpin\Xpadder 2013.07.18.exe
				joyToKeyFullPath = C:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = C:\HyperSpin\HyperLaunch\Profiles\xpadder
				keymapperHyperLaunchProfileEnabled = true
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				JoyIDsPreferredControllersGlobal =
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				rotateMethod = false
				FEProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperSpin
				defaultProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default
				systemProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System
				xPadderSystemProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System\_Default
				emuProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System\Fceux
				romProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System\RoadBlasters (USA)
				HyperLaunchProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperLaunch
				blankProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default\blank
				ahkFEProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\Nintendo Entertainment System
				ahkEmuProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\Nintendo Entertainment System\Fceux
				ahkRomProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\Nintendo Entertainment System\RoadBlasters (USA)
				ahkHyperLaunchProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				bezelICEnabled = false
				statisticsEnabled = true
				pressDuration = -1
				emuVolume = 1
				dxwndIni = C:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini
				dxwndFullPath = C:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe
				mon1O = 0
				pacDrivedllFile = C:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll
				userFadeAnimIniFile = C:\HyperSpin\HyperLaunch\Lib\User Fade Animations.ini
16:44:41:993 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
16:44:41:993 | HL |     INFO  | +0     | BuildScript - Loaded HyperPause Init.ahk scripts
16:44:41:993 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
16:44:41:993 | HL |  WARNING  | +0     | BuildScript - "C:\HyperSpin\HyperLaunch\Lib\User Functions Init.ahk" not found
16:44:41:993 | HL |     INFO  | +0     | BuildScript - Validating module
16:44:41:993 | HL |     INFO  | +0     | BuildScript - Validation complete
16:44:41:993 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = Fceux
				MEmuV =  r2699
				MURL = http://www.fceux.com/web/home.html
				MAuthor = djvj
				MVersion = 2.0
				MCRC = D4C79C64
				iCRC =
				MID = 635038268889762139
				MSystem = "Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System"
				; Notes:
				; To set fullscreen, goto Config->Video and check Enter full screen mode after game is loaded. Leave Full Screen unchecked.
				StartModule()
				FadeInStart()
				Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath)
				WinWait("ahk_class FCEUXWindowClass")
				WinWaitActive("ahk_class FCEUXWindowClass")
				FadeInExit()
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				CloseProcess:
					FadeOutStart()
					WinClose("ahk_class FCEUXWindowClass")
				Return
16:44:41:002 | HL |     INFO  | +16    | BuildScript - Loaded HyperPause scripts
16:44:42:004 | HL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
16:44:42:005 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
16:44:42:006 | HL |  WARNING  | +0     | BuildScript - "C:\HyperSpin\HyperLaunch\Lib\User Functions.ahk" not found
16:44:42:006 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
16:44:42:007 | HL |     INFO  | +0     | Main - Module is built
16:44:42:007 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
16:44:42:011 | HL |     INFO  | +0     | Main - Running module
I'm using Hyperlaunch V 3.1.0
Everytime my hyperlaunch fails to load emulators, I first open up processes to see if the emulator is still running while I ran the exit command on my gamepad in hyperspin. If that checks out, I move onto the fact that Hyperlaunch is still running in my processes everytime and I end the process. I try to run another emulator through hyperspin and it never fixes the problem until I restart my computer, and even then it has taken up to 4 times restarting to fix this problem... :facepalm: I have also tried closing the hyperlaunch process through HyperlaunchHQ on the last tab and it also is no help. Let me know if you need more information, I have nothing to do but fix this problem for the next 5 hours.
*EDIT* I restarted my computer when I had no emulators able to load, got SNES able to load first try because of restart and decided to check the logs and saw an odd error. An error on a working attempt of hyperspin loading emulators. I'll post these logs I just got in case they could help.
17:36:42:156 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.4 BETA (www.hyperlaunch.net)
17:36:42:609 | HL |     INFO  | +452   | Main - System Specs:
				SKU: Ultimate
				Free Memory: 6248.55 MB
				Used Memory: 1941.938 MB
				SystemType: 64-bit
				AutoHotkey Path:
				Unicode: No
17:36:42:609 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
17:36:42:610 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
17:36:42:619 | HL |     INFO  | +16    | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
17:36:42:634 | HL |  WARNING  | +15    | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-f <PATH_TO_MY_FE\FRONTEND.exe>"
17:36:42:636 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x448 y156 w1024 h768
17:36:42:636 | HL |  WARNING  | +0     | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to HyperLaunch: "-p <PLUGINTYPE>"
17:36:42:636 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Plugins\HyperSpin.plugin exists
17:36:42:663 | HL |     INFO  | +31    | Main - HyperLaunch received "Super Nintendo Entertainment System" and "3 Ninjas Kick Back (USA)"
17:36:42:708 | HL |     INFO  | +32    | Main - 3 Ninjas Kick Back (USA) is using the default emulator: Snes9x
17:36:42:708 | HL |     INFO  | +0     | Main - Checking for a [snes9x] section in C:\HyperSpin\HyperLaunch\Settings\Super Nintendo Entertainment System\Emulators.ini
17:36:42:709 | HL |     INFO  | +0     | Main - Checking for a [snes9x] section in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
17:36:42:710 | HL |     INFO  | +15    | Main - Found [snes9x] in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
17:36:42:721 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Modules\Snes9x\Snes9x.ahk exists
17:36:42:816 | HL |     INFO  | +94    | Main - CRC Check - CRC matches, this is an official unedited module.
17:36:42:816 | HL |     INFO  | +0     | Main - 3 Ninjas Kick Back (USA) will use module: C:\HyperSpin\HyperLaunch\Modules\Snes9x\Snes9x.ahk
17:36:42:831 | HL |     INFO  | +15    | Main - Did not find a "C:\HyperSpin\HyperLaunch\Settings\Super Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options.
17:36:42:831 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
17:36:42:834 | HL |     INFO  | +0     | Main - INI Keys read
17:36:42:834 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
17:36:42:854 | HL |     INFO  | +32    | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
17:36:42:870 | HL |     INFO  | +15    | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\FontReg.exe exists
17:36:42:933 | HL |     INFO  | +63    | Main - "3 Ninjas Kick Back (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
17:36:42:933 | HL |     INFO  | +0     | CheckPaths - Started
17:36:42:933 | HL |     INFO  | +0     | CheckPaths - Found rom: C:\Users\Jason\Desktop\SNES Roms\3 Ninjas Kick Back (USA).sfc
17:36:42:933 | HL |     INFO  | +0     | CheckPaths - Ended
17:36:42:934 | HL |     INFO  | +0     | BuildScript - User Variables:
				#NoTrayIcon
				#InstallKeybdHook
				SendMode, Event
				0 = 2
				pluginExt = .plugin
				hlMode =
				hlAuthor = djvj
				frontendPID = 5604
				frontendExt = exe
				frontendDrive = C:
				exitEmulatorKey = 4joy9&4joy10|5joy9&5joy10|1joy9&1joy10|2joy9&2joy10|6joy7&6joy8|3joy7&3joy8|7joy7&7joy8|9joy7&9joy8|8joy7&8joy8|~Esc
				forceHoldKey = ~esc
				restoreFE = false
				emuFullPath = C:\HyperSpin\Emulators\Snes9x\snes9x-1.53-win32-x64\Snes9X1.52\snes9x.exe
				emuPath = C:\HyperSpin\Emulators\Snes9x\snes9x-1.53-win32-x64\Snes9X1.52
				emuName = Snes9x
				emuExt = exe
				romPath = C:\Users\Jason\Desktop\SNES Roms
				romPathFromIni = C:\Users\Jason\Desktop\SNES Roms
				romExtension = .sfc
				romExtensionOrig = .sfc
				romExtensions = 7z|zip|sfc|smc
				executable = snes9x.exe
				systemName = Super Nintendo Entertainment System
				dbPath =
				dbName = 3 Ninjas Kick Back (USA)
				dbExt =
				romName = 3 Ninjas Kick Back (USA)
				romMapPath =
				altRomNameOnly =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = false
				blockInputTime = 0
				lockLaunch = false
				lockLaunchGame =
				logLevel = 3
				sysType = 64-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				dtEnabled = false
				dtPath =
				dtUseSCSI = false
				dtAddDrive = true
				ledblinkyFullPath =
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOut = false
				fadeOutDelay = 0
				fadeLyr2X = 0
				fadeLyr2Y = 0
				fadeLyr2W =
				fadeLyr2H =
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3X = 450
				fadeLyr3Y = 450
				fadeLyr3W =
				fadeLyr3H =
				fadeLyr3PicPad = 0
				fadeLyr3Speed = 750
				fadeLyr3Repeat = 1
				fadeLyr3StaticX = 0
				fadeLyr3StaticW =
				fadeLyr3StaticH =
				fadeLyr4Adjust = 1
				fadeLyr4W = 128
				fadeLyr4H =
				fadeLyr4FPS = 50
				fadeLyr4PicPad = 0
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowR = 30
				fadeBarWindowM = 30
				fadeBar = 7zOnly
				fadeBarBack = true
				fadeBarH = 30
				fadeBarR = 10
				fadeBarXOffset = 0
				fadeText1X = 0
				fadeText1Y = 0
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				moduleFullName = C:\HyperSpin\HyperLaunch\Modules\Snes9x\Snes9x.ahk
				moduleName = Snes9x
				modulePath = C:\HyperSpin\HyperLaunch\Modules\Snes9x
				7zEnabled = false
				7zExtractPathOrig =
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgSidePadding = 0.2
				mgYOffset = 500|800
				mgFont = Arial
				mgText2Offset = 100
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = true
				hpKey = NumpadAdd
				hpZoomInKey = C
				hpZoomOutKey = V
				hpSaveStateKeyCodes = {Shift down}{F1 down}{F1 up}{Shift up}|{Shift down}{F2 down}{F2 up}{Shift up}|{Shift down}{F3 down}{F3 up}{Shift up}|{Shift down}{F4 down}{F4 up}{Shift up}|{Shift down}{F5 down}{F5 up}{Shift up}|{Shift down}{F6 down}{F6 up}{Shift up}|{Shift down}{F7 down}{F7 up}{Shift up}|{Shift down}{F8 down}{F8 up}{Shift up}|{Shift down}{F9 down}{F9 up}{Shift up}|{Shift down}{F10 down}{F10 up}{Shift up}
				hpLoadStateKeyCodes = {F1 down}{F1 up}|{F2 down}{F2 up}|{F3 down}{F3 up}|{F4 down}{F4 up}|{F5 down}{F5 up}|{F6 down}{F6 up}|{F7 down}{F7 up}|{F8 down}{F8 up}|{F9 down}{F9 up}|{F10 down}{F10 up}
				keymapper = xpadder
				CustomJoyNames =
				systemProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System
				xPadderSystemProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System\_Default
				emuProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System\Snes9x
				romProfile = C:\HyperSpin\HyperLaunch\Profiles\xpadder\Super Nintendo Entertainment System\3 Ninjas Kick Back (USA)
				ahkSystemProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\Super Nintendo Entertainment System
				ahkEmuProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\Super Nintendo Entertainment System\Snes9x
				ahkRomProfile = C:\HyperSpin\HyperLaunch\Profiles\AHK\Super Nintendo Entertainment System\3 Ninjas Kick Back (USA)
				pressDuration = -1
				emuVolume = 1
				mon1O = 0
17:36:42:950 | HL |     INFO  | +15    | BuildScript - Loaded XHotkey Init.ahk scripts
17:36:42:970 | HL |     INFO  | +16    | BuildScript - Loaded HyperPause Init.ahk scripts
17:36:42:978 | HL |     INFO  | +15    | BuildScript - Loaded Statistics Init.ahk scripts
17:36:42:978 | HL |  WARNING  | +0     | BuildScript - "C:\HyperSpin\HyperLaunch\Lib\User Functions Init.ahk" not found
17:36:42:978 | HL |     INFO  | +0     | BuildScript - Validating module
17:36:42:979 | HL |     INFO  | +0     | BuildScript - Validation complete
17:36:42:979 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = Snes9X
				MEmuV =  v1.53
				MURL = http://www.snes9x.com/
				MAuthor = djvj
				MVersion = 2.0.1
				MCRC = 34FD2149
				iCRC = FD5A1CE
				MID = 635038268923820476
				MSystem = "Nintendo Super Famicom","Super Nintendo Entertainment System"
				; Notes:
				; Fullscreen is controlled via the variable below
				; snes9x adjusts the windowed resolutions in the ini automatically based on the settings you choose below.
				; Bezels work, but if you notice a black bar along the bottom, change this option to false in snes9x.conf: ExtendHeight
				StartModule()
				BezelGUI()
				FadeInStart()
				EmulateFullscreen := IniReadCheck(settingsFile, "Settings", "EmulateFullscreen","true",,1)		; This helps fading look better and work better on exit. You cannot use this with a normal fullscreen so one has to be false
				WindowMaximized := IniReadCheck(settingsFile, "Settings", "WindowMaximized","true",,1)
				Stretch := IniReadCheck(settingsFile, "Settings", "Stretch","true",,1)
				MaintainAspectRatio := IniReadCheck(settingsFile, "Settings", "MaintainAspectRatio","true",,1)
				HideMenu := IniReadCheck(settingsFile, "Settings", "HideMenu","true",,1)
				FullScreenWidth := IniReadCheck(settingsFile, "Settings", "FullScreenWidth","1024",,1)
				FullScreenHeight := IniReadCheck(settingsFile, "Settings", "FullScreenHeight","768",,1)
				snes9xConf := CheckFile(emuPath . "\snes9x.conf")
				BezelStart()
				; Now let's update all our keys if they differ in the ini
				iniLookup =
				( ltrim c
				   Display\Win, Fullscreen:Enabled, %Fullscreen%
				   Display\Win, Fullscreen:EmulateFullscreen, %EmulateFullscreen%
				   Display\Win, Window:Maximized, %WindowMaximized%
				   Display\Win, Stretch:Enabled, %Stretch%
				   Display\Win, Stretch:MaintainAspectRatio, %MaintainAspectRatio%
				   Display\Win, Fullscreen:Width, %FullScreenWidth%
				   Display\Win, Fullscreen:Height, %FullScreenHeight%
				   Display\Win, HideMenu, %HideMenu%
				Loop, Parse, iniLookup, `n
				{	StringSplit, split, A_LoopField, `,, %A_Space%%A_Tab%
					IniRead, tempVar, %snes9xConf%, %split1%, %split2%
					If ( tempVar != split3 )
						IniWrite, % split3, %snes9xConf%, %split1%, %split2%
				WinWait("Snes9X ahk_class Snes9X: WndClass")
				WinWaitActive("Snes9X ahk_class Snes9X: WndClass")
				BezelDraw()
				FadeInExit()
				BezelExit()
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				CloseProcess:
					FadeOutStart()
					WinClose("Snes9X ahk_class Snes9X: WndClass")
				Return
17:36:43:175 | HL |     INFO  | +188   | BuildScript - Loaded HyperPause scripts
17:36:43:198 | HL |     INFO  | +31    | BuildScript - Loaded Multi-Player scripts
17:36:43:203 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
17:36:43:204 | HL |  WARNING  | +0     | BuildScript - "C:\HyperSpin\HyperLaunch\Lib\User Functions.ahk" not found
17:36:43:204 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
17:36:43:206 | HL |     INFO  | +0     | Main - Module is built
17:36:43:206 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
17:36:43:275 | HL |     INFO  | +78    | Main - Running module
17:36:43:430 | MD |     INFO  | +N/A   | Module initialized
17:36:43:607 | MD |     INFO  | +172   | StartModule - Started
17:36:43:607 | MD |     INFO  | +0     | StartModule - MEmu: Snes9X
				MEmuV: v1.53
				MURL: http://www.snes9x.com/
				MAuthor: djvj
				MVersion: 2.0.1
				MCRC: 34FD2149
				iCRC: FD5A1CE
				MID:
				MSystem: "Nintendo Super Famicom","Super Nintendo Entertainment System"
17:36:43:607 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Super Nintendo Entertainment System"
17:36:43:631 | MD |     INFO  | +31    | PluginInit - Started
17:36:43:631 | MD |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml exists
17:36:43:890 | MD |     INFO  | +249   | PluginInit - Ended
17:36:43:891 | MD |     INFO  | +0     | StartModule - Ended
17:36:43:891 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
17:36:43:891 | MD |     INFO  | +0     | Module Setting - [settings] - EmulateFullscreen: true
17:36:43:891 | MD |     INFO  | +0     | Module Setting - [settings] - WindowMaximized: true
17:36:43:891 | MD |     INFO  | +0     | Module Setting - [settings] - Stretch: true
17:36:43:891 | MD |     INFO  | +0     | Module Setting - [settings] - MaintainAspectRatio: true
17:36:43:892 | MD |     INFO  | +0     | Module Setting - [settings] - HideMenu: true
17:36:43:892 | MD |     INFO  | +0     | Module Setting - [settings] - FullScreenWidth: 1024
17:36:43:892 | MD |     INFO  | +0     | Module Setting - [settings] - FullScreenHeight: 768
17:36:43:892 | MD |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Emulators\Snes9x\snes9x-1.53-win32-x64\Snes9X1.52\snes9x.conf exists
17:36:43:945 | MD |     INFO  | +63    | Run - Running: C:\HyperSpin\Emulators\Snes9x\snes9x-1.53-win32-x64\Snes9X1.52\snes9x.exe "C:\Users\Jason\Desktop\SNES Roms\3 Ninjas Kick Back (USA).sfc"
17:36:44:101 | MD |     INFO  | +156   | WinWait - Waiting for "Snes9X ahk_class Snes9X: WndClass"
17:36:45:133 | MD |     INFO  | +1029  | WinWaitActive - Waiting for "Snes9X ahk_class Snes9X: WndClass"
17:36:45:282 | MD |     INFO  | +141   | Process - WaitClose snes9x.exe
17:36:54:368 | MD |    ERROR  | +9095  | 2
17:36:54:368 | MD |     INFO  | +0     | WinClose - Closing: Snes9X ahk_class Snes9X: WndClass
17:36:54:602 | MD |     INFO  | +234   | ExitModule - Started
17:36:54:603 | MD |     INFO  | +0     | Starting Updating Statistics:
17:36:54:994 | MD |     INFO  | +390   | Game section statistics updated.
17:36:54:994 | MD |     INFO  | +0     | ExitModule - Ended
17:36:54:994 | MD |     INFO  | +0     | End of Module Logs
17:36:55:004 | HL |     INFO  | +11731 | Main - Module ended, exiting HyperLaunch normally
17:36:55:004 | HL |     INFO  | +0     | ExitScript - Started
17:36:55:024 | HL |     INFO  | +16    | SystemCursor - Restoring mouse cursor
17:36:55:032 | HL |     INFO  | +0     | ExitScript - Ended
From watching my Hyperlaunch process very closely I have almost pinpointed when it goes wrong. I just had an instance of Hyperlaunch "Opening" and running when I tried to run a rom on SNES, the emulator never opened and Hyperspin just sat there. I checked to see if Snes9x was running and it wasn't. Closed the process for Hyperlaunch and still can't load games until I restart my computer like every other time. Not sure how I can be running hyperlaunch without it opening up an emulator. It is definitely the root of my problem though, still cant find a solution for it.
Ok lets do a reset here. Start from the beginning, and forget about Hyperspin for now.
Do you have fade and bezels enabled which could be hiding a problem? What are your settings in HyperlaunchHQ, and can you launch games through HyperlaunchHQ? Is this your first set up, or did you have it working at some point? What changed, etc etc.
Also, stop restarting your computer so much. This should not require a restart, and I'm no guru, but I don't think that's good for it.
Walter:beerglass:
Fade and Bezels are both turned off for all systems.
I recently went through HyperlaunchHQ and cleared most settings to default to check if it was something I set and it was not.
I can launch games through HyperlaunchHQ normally, until something causes the mess up and then I can't launch games through it.
I did have this setup working at some point where this problem did not occur, it's difficult to remember when this started. Since this problem has only happened when trying to run games on SNES (Snes9X) and NES (Was Nestopia, changed to FCEUX trying to fix this) I feel that it might be caused by the emulators themselves. Possibly due to an incorrect version being ran against what the module accepts as a working version.
So, it reiterate the problem. Hyperlaunch goes from: Not running -> Running while either of the two emulators do NOT load (at all) properly which begins the problem of no other emulator loading. When the two emulators are "running" as hyperlaunch states, there are no processes to close for the emulators and closing the process of hyperlaunch does not yield and results.
Let me know if you need more specific information on HLHQ settings.
Dude I'm sorry. I've been trying to wrap my head around this, and I got nothing. The only process that would cause ALL emulators not to start is the hyperlaunch.exe process. Even having a version of snes9x, for example, running shouldn't stop you from being able to use mame. So here's a few things:
Check in HyperHQ that executable is indeed set to Hyperlaunch and not Normal. (Just to be sure, do this for all systems)
I'm correct in assuming only those two emulators will start this chain reaction? ie you can run mame as many times as you want and it'll never lock up the other emulators?
To test the above hypothesis: next time it locks up, try running various emulators stand alone and post results.
Are you SURE SURE that hyperlaunch.exe is closing? (If it isn't, it could be a version problem or even what you have set up as your exit key) Also note that for me at least the hyperlaunch process isn't called hyperlaunch exe, I can't remember exactly what it is for me, its something like Your favorite Front End Companion so double and triple check that this is closed.
Lastly, try an emulator that handles multiple systems including snes, I recommend retroarch, but bizhawk and mednafen and mess are options. If that works, you know the problem is with snes9x.
Walter:beerglass:
I've done some testing with what you replied. All HyperHQ settings for the wheels are set to Hyperlaunch and not Normal. I ran a lot of emulators last night in sequence and ill show what I found.
NES - Good
SNES - Good
N64 - Good
GBA - Good
Gameboy - Good
Gameboy Color - Good
Gamecube - Good
Wii - Good
Sega 32X - Good
Dreamcast - Good
Genesis - Good
PS1 and PS2 - Good
PSP - Good
MAME - Good
(All emulators were closed properly using a controller with exit keys of Select + Start set through HyperlaunchHQ)
This was all of my emulators and they all worked, I do have 7 manufacturer MAME sets as well which I didn't have time to test but since they run off of Mame I was guessing they would work too. While testing the PS1 I did have 3 exceptions throughout that said I needed to check that the emulator version was correct and that fade was turned off. It didn't break Hyperlaunch, it only took 30 seconds or so to run another game. It also happened one additional time when I switched to the first PS2 game to test.
So today, I turned on my computer and tried to load up any emulator and surprisingly nothing worked, it was almost flawless last night but this morning I get nothing.
When the system breaks, Hyperlaunch.exe doesn't close properly because the emulator never starts. So it can't close properly with any of the exit keys. Even the exit script keys closing the correct process doesn't fix it. My exit keys are Start + Select buttons across 9 controllers that I use. I also kept ~Esc, not sure what the tilda (~) is for but I used them before each button press so it looks like this, ~4joy9&~4joy10. I've done testing using only my keyboard with the original exit key of ~Esc and it still breaks Hyperlaunch but maybe my Select + Start keys are messing something up, idk.
I think i'll review my emulators and see what versions the modules run on and switch whatever isn't. I've put so much work into my hyperspin, really hoping this problem can be fixed so I can sleep better at night :P
*EDIT* You've GOT to be kidding me. I feel so frustrated, angry, and relieved all at once. I went into HyperlaunchHQ and deleted ALL my exit keys and set ~Esc to be the only remaining exit key. While my Hyperlaunch was failing to run for the last 30 minutes, I closed out of the process one more time and it... worked. For some odd reason my mouse is invisible, but other than that i'll report back to see if everything works properly. I only just now remember what I changed last before the whole system broke haha wow.
*EDIT2* It works flawlessly, i'm shocked right now. I can't thank you enough, I've had this problem for 3 weeks now and it's very frustrating when friends are over and my emulators stop working haha. Again, holy crap, thank you.
