Ini issue
northern24
I completed a fresh install of hyperspin but I'm not sure I have done it correctly as when I load fusion it states it cannot find the fusion ini file in an error message, I have checked hyperspin and the fusion ini word documents have populated the emulator information in the hyperlaunch setting directory but not in the hyperspin setting directory. I could populate the hyperspin fusion setting ini file manually but if that is the issue why has it not populated itself when I used the hyperlaunch HQ GUI setup? is it because when I first loaded hyperspin hq it did not ask for the location of the hyperlaunch exe file like it used to on earlier hyperspin versions I have tried.
I only wish there was someone in the Norfolk area of England except me who was into hyperspin to advise me as I'm sure its something easy to sort but it seems every time I get answered one question it creates two more, this is getting more confusing than an episode of lost.
Cheers for any reply I get
Do I need to be from Norfork to answer this? ;) I do have family in Norfolk, perhaps that counts?
Have you run Fusion yet? Perhaps it's looking for the Fusion ini which may only be created once run or after you make changes.
Please post your HyperLaunch log set to troubleshooting.
