andyco40 Posted March 22, 2015 Posted March 22, 2015 hi all does anyone no how to use pinball FX2 with nukelauncher and not the module for hyperlaunch thanks.
rfancella Posted March 25, 2015 Posted March 25, 2015 What advantage does the launcher have over the existing Pinball FX2 module? If there is an advantage, i'd be gladto take a peek. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
andyco40 Posted March 25, 2015 Author Posted March 25, 2015 with the module it never runs first time, when i boot up machine for first time and run pinball fx2 it dont select my table it just stays at southpark waiting for me to select a table. so i exit out of it and select a table again and it runs fine and selects my table i choosen. with nuke launcher it run the first time with no problems. it also does the same with pinball arcade that never works first time either but ok if i run it again.
rfancella Posted March 25, 2015 Posted March 25, 2015 Hmmm... I can't get it to work for me. I changed the XMLFile to point to my database. I now get a pop up dialogue box that says "Good news" and to click OK. Just sits there. When I click OK. It goes on but always selects the first game in my grid. I changed the grid to 9x6, and now it selects nothing. Yea, 9x6 is not described as an option in the ini. But that's what my setup has. Changed it back to 7x7 and it selects a game, but will not hit play. I'll blow it away and try again... But not promising on my setup. :S Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
andyco40 Posted March 25, 2015 Author Posted March 25, 2015 ok thanks i have pinball fx2 setup in my pincab with nukelouncher and it works brill, so thought id try it in my arcade cab cus the module for the pinball fx2 never works the first time only the 2nd time when i run it. i have tryed it with nukelauncher in arcade cab but it always uses the module and i dont want it to.
rfancella Posted March 25, 2015 Posted March 25, 2015 ok thanks i have pinball fx2 setup in my pincab with nukelouncher and it works brill, so thought id try it in my arcade cab cus the module for the pinball fx2 never works the first time only the 2nd time when i run it. i have tryed it with nukelauncher in arcade cab but it always uses the module and i dont want it to. lol I haven't given up yet. I figured out what my problem with nukelauncher is. It didn't guess all the right tables and they were out of order. I messed with the timing and it works. I think your issue with your cab and the module is timing as well. When I run it on my cab, it runs with all the defaults just fine. When I run it on my PC, with other processes running also, I have to adjust the timings to get it right. But as far as I can see, there is nothing that nukelauncher can do that the official module can not. Try this: The nukelauncher initial sleep is defaulted to 15000 where as the module is defaulted to 12000. Try setting that to 15000 in the module settings. See if that resolves your issue with the first launch. If it's still not picking the right game, try increasing the Sleep_Base_Time from default (1) to 1.5 or 2. This will slow the launch way down, but if the game does launch correctly, you know it's in the timing. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
andyco40 Posted March 25, 2015 Author Posted March 25, 2015 that did the trick change it to 15000 and that worked and its picking the right tables thanks for the help.
rfancella Posted March 25, 2015 Posted March 25, 2015 that did the trick change it to 15000 and that worked and its picking the right tables thanks for the help. Sweet! I have one question. Do you have the football (soccer) table? Does the x2 and y2 allow you to launch the table instead of choosing a team?? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted March 25, 2015 Posted March 25, 2015 u mean the zen table Yes, The Zen Pinball FX2 table Football Super League. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted March 25, 2015 Posted March 25, 2015 here is my ini if it helps Ahhh. Got it. When you go to Zen Football. it gives a list of different football tables. I'll play around with mine a bit and see how it all works. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
andyco40 Posted March 25, 2015 Author Posted March 25, 2015 if u run pinball fx2 on its own outside if hyperspin and go to the football selection were the teams are and select the one in the left top pinbasll fx2 will remember and it should work then.
Outhere Posted March 27, 2015 Posted March 27, 2015 when you say -- existing Pinball FX2 module? Are you referring to Pinball fx2.ahk file?
Outhere Posted March 27, 2015 Posted March 27, 2015 What advantage does the launcher have over the existing Pinball FX2 module? If there is an advantage, i'd be gladto take a peek.Thanks, Ron when you say -- existing Pinball FX2 module? Are you referring to Pinball fx2.ahk file?
rfancella Posted March 27, 2015 Posted March 27, 2015 when you say -- existing Pinball FX2 module? Are you referring to Pinball fx2.ahk file? Correct. The current Pinball FX2 module (Pinball FX2.ahk) is version 2.0.5. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
mymichelle Posted March 27, 2015 Posted March 27, 2015 Hi! I'm in trouble with the nukelauncher on Pinball X in order to open correct Pinball Fx2 tables. The system launch always the first table! I have a local version of Pinball Fx2...no steam! I try to change different settings but nothing good news yet! Can you help me please?
rfancella Posted March 27, 2015 Posted March 27, 2015 Hi! I'm in trouble with the nukelauncher on Pinball X in order to open correct Pinball Fx2 tables. The system launch always the first table!I have a local version of Pinball Fx2...no steam! I try to change different settings but nothing good news yet! Can you help me please? Hello and welcome to the forum. Try using Pinball FX2 without nukelauncher. The Pinball FX2 module in HyperLaunch will do everything that the launcher does. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Outhere Posted March 28, 2015 Posted March 28, 2015 Correct. The current Pinball FX2 module (Pinball FX2.ahk) is version 2.0.5.Thanks, Ron Where does one get this file
rfancella Posted March 29, 2015 Posted March 29, 2015 Where does one get this file It is included in the HyperLaunch/RocketLaunch update. Check the RocketLauncher web site for details. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
