StuartPD Posted March 25, 2015 Posted March 25, 2015 Hi guys! New user to HypeSpin, and so far I'm loving it! After many hours, I've managed to get my NES ROMS & emulator to working as intended, but have run into an issue with my Super Nintendo emulators/ROMs. I've been hunting high & low on these forums & have seen issues regarding a bug with the having speakers unplugged, but that doesn't seem to be my issue. I've checked over my settings in HyperLaunchHQ & HyperHQ, and everything to me seems to be setup correctly. I've checked both zSnes & Snes9x, and they both work outside of HyperSpin. I've also made sure I am using the correct module, with the correct version of each emulator. I know it's probably something simple, but it has me stumped?! If anyone could give me a hand, it would be most appreciated. Logs to follow... Thanks Snes9x 09:38:27 PM | HyperSpin Started 09:38:27 PM | Going FullScreen 09:38:27 PM | Checking for updates 09:38:27 PM | Update Check Complete 09:38:27 PM | Startup program: HyperSpin Startup Script.exe 09:38:27 PM | Startup params not set 09:38:27 PM | Working directory: C:\Games\Emulators & ROMS\HyperSpin\Utilities\Startup Script\ 09:38:27 PM | Window State: NORMAL 09:38:27 PM | Launching HyperSpin Startup Script.exe 09:38:27 PM | Command Line is HyperSpin Startup Script.exe 09:38:27 PM | Error intializing joysticks 09:38:27 PM | Menu Mode is multi 09:38:28 PM | Loading Main Menu.xml 09:38:28 PM | Main Menu.xml successfully loaded 09:38:28 PM | Main Menu wheel loaded successfully 09:38:32 PM | Loading Super Nintendo Entertainment System.xml 09:38:32 PM | Main Menu.xml successfully loaded 09:38:33 PM | Super Nintendo Entertainment System wheel loaded successfully 09:38:37 PM | Launching Game 09:38:37 PM | Using HyperLaunch 09:38:37 PM | Getting HyperLaunch path 09:38:37 PM | HyperLaunch located at C:\Games\Emulators & ROMS\HyperSpin\HyperLaunch.exe 09:38:37 PM | Running HyperLaunch.exe 09:38:37 PM | HyperLaunch Command Line is: C:\Games\Emulators & ROMS\HyperSpin\HyperLaunch.exe "Super Nintendo Entertainment System" "3 Ninjas Kick Back (USA)" 09:38:41 PM | Loading Main Menu.xml 09:38:41 PM | Main Menu.xml successfully loaded 09:38:42 PM | Main Menu wheel loaded successfully 09:38:43 PM | Exit program unavailable 09:38:43 PM | Quiting Hyperspin 09:38:43 PM | Bye! Znes 09:42:27 PM | HyperSpin Started 09:42:27 PM | Going FullScreen 09:42:27 PM | Checking for updates 09:42:27 PM | Update Check Complete 09:42:27 PM | Startup program: HyperSpin Startup Script.exe 09:42:27 PM | Startup params not set 09:42:27 PM | Working directory: C:\Games\Emulators & ROMS\HyperSpin\Utilities\Startup Script\ 09:42:27 PM | Window State: NORMAL 09:42:27 PM | Launching HyperSpin Startup Script.exe 09:42:27 PM | Command Line is HyperSpin Startup Script.exe 09:42:27 PM | Error intializing joysticks 09:42:27 PM | Menu Mode is multi 09:42:27 PM | Loading Main Menu.xml 09:42:27 PM | Main Menu.xml successfully loaded 09:42:28 PM | Main Menu wheel loaded successfully 09:42:31 PM | Loading Super Nintendo Entertainment System.xml 09:42:31 PM | Main Menu.xml successfully loaded 09:42:32 PM | Super Nintendo Entertainment System wheel loaded successfully 09:42:35 PM | Launching Game 09:42:35 PM | Using HyperLaunch 09:42:35 PM | Getting HyperLaunch path 09:42:35 PM | HyperLaunch located at C:\Games\Emulators & ROMS\HyperSpin\HyperLaunch.exe 09:42:35 PM | Running HyperLaunch.exe 09:42:36 PM | HyperLaunch Command Line is: C:\Games\Emulators & ROMS\HyperSpin\HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)" 09:42:50 PM | Launching Game 09:42:50 PM | Using HyperLaunch 09:42:50 PM | Getting HyperLaunch path 09:42:50 PM | HyperLaunch located at C:\Games\Emulators & ROMS\HyperSpin\HyperLaunch.exe 09:42:50 PM | Running HyperLaunch.exe 09:42:50 PM | HyperLaunch Command Line is: C:\Games\Emulators & ROMS\HyperSpin\HyperLaunch.exe "Super Nintendo Entertainment System" "3 Ninjas Kick Back (USA)" 09:42:56 PM | Loading Main Menu.xml 09:42:56 PM | Main Menu.xml successfully loaded 09:42:57 PM | Main Menu wheel loaded successfully 09:43:00 PM | Exit program unavailable 09:43:00 PM | Quiting Hyperspin 09:43:00 PM | Bye!
gigapig Posted March 26, 2015 Posted March 26, 2015 Hello StuartPD and welcome to the forum. You've obviously recently set this up, did you download and install HyperLaunch into the correct folder structure from here? If you didn't do that, then that's your first job, so check out a guide if you need to. Thank you for posting the HyperSpin log, it tells me that HyperSpin is using the old HyperLaunch which is in the root of HyperSpin. Please read this thread to sort that out. If you still have issues once HyperLaunch is working, please post your HyperSpin log and the HyperLaunch log set to troubleshooting.
