ninja2bceen Posted March 27, 2015 Posted March 27, 2015 Hi many have asked for it and this is pretty close I think... I still need to try it but it's promising. All props go to xttx below. I'm still reading up on it it is in active development. The latest version is here http://www.rus-tutorials.ru/files/mCheat_0.008_Alpha.zip (not easy to setup though, and support limited number of emulators (can be found in config.xml)) More info here (google-translated): https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Fwww.rus-tutorials.ru%2Ffajly%2F10-mcheats-chit-programma-dlya-emulyatorov&sandbox=1 Basically, all you need is to launch mcheat.exe (it will be mimimaized in tray), than launch any of supported emulators than use Ctrl+E to show menu, arrows to navigate, "END" button to activate/deactivate cheats and enter submenus, backspace to return from submenu or close main menu. You have to have .net framework 4 installed. And if you plan to use it on 64x OS with 32 bits emulators (most of them are 32 bits), you need to launch "Register SlimDX.bat" before using the app. If you want to use gamepad to load/save quickstates and change slots, right click on tray icon and choose "Configure joystic". The savestate controls for supported emulators are already predefined. Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Undertow76 Posted April 14, 2015 Posted April 14, 2015 Looks promising, I will have to test this out!
