AAE games not launching from hyperlaunch/hyperspin
kenshutt97
Using AAE as the emulator, it launches the game, but I can't set any joystick controls
Using MAME as the emulator, it tries to launch and the window just goes away.
Using Retroarch, it just loads to select core options.
What am I missing? is there a bios file that I'm not seeing that I should place? I have quite a few mame/retroarch systems that are working.
I have AAE setup.
Are you saying AAE won't save your controls after you have configure them (tab key)?
Have you launched AAE outside of hyper launch and hyperspin then tried configuring your controls then?
Some emulators don't save their settings when launched via hyperlaunch.
I'm away from my PC at the moment.... I might be using xpadder for this system.
/just checked.... Yes I have xpadder setup to remap the keys for my gamepad.
  austin585 said:
MAME actually plays AAE much better than the EMU now. Plus with HLSL it looks almost like the original too.... very nice :)
I haven't tried mame in a while but I have read also that it's the best way to go for vector games.
I'm gonna wait until my pc gets upgraded before attempting to add hlsl as I heard it needs some cpu grunt.
I'd love to use mame. I can't get it to work :(
  rexryan said:
i remember when i set this up to get it to work in hyperspin you have to remove the # sign in the settings.
Any idea which settings you're referring to?
in your emulator folder under the AAE ini. It's listed as a module note always try to follow them to get the to launch in hyperspin.
Sorry, I thought you meant for MAME. I have it working using the AAE emulator, but I wish to NOT use AAE, but rather Mame. AAE doesn't allow joysticks to be configured. I want to get MAME to work with my AAE roms.
MAME Tutorial with HSLSL or whatever plus downloads it is included in my tutorial for MAME... take a look in my Sig and watch the vid... easy peasy :)
Hey Austin. I've seen just about all of your videos I think. I don't see or recall anything with AAE. I have MAME working fine with normal Mame roms and other systems that use MAME, but I just can't get it to work with AAE. When switching it to mame in HL, it just flashes and nothing happens. AAE loads with AAE emulator, but not Mame emulator
If you have the current version of HyperlaunchHQ and you have MAME already installed is point the ROMS bit in AAE to your MAME roms folder and choose MAME as the default emulator for it.
Everything in AAE is included in MAME. Only thing in theory it needs is the database to make it work
Current version of HyperLaunch HQ (v1.1.1.3).
AAE is on the left in system list.
Rom path is set to ..\ROMS\AAE.
Default Emulator set to MAME.
On the Games tab for AAE, Audit shows all games as green
Mame Module is set using djvj version for Mame 0.159, which is the Mame version I'm using. Module version 2.1.6, which is most up to date that I see. (came with hyperlaunch)
Mame.ini is in modules, which is the same as the mame example that was included.
Database for AAE is listed in Databases\AAE. it's using version 1.0.
Roms are in the directory that hyperlaunch is pointing to. Make is set to read zip and 7z and just in case, i put AAE. The roms are in .zip format.
When I click launch from hyperlaunch on any of the games, MAME just flashes and closes immediately.
Set Rom path to /ROMS/MAME or wherever your MAME 0.159 version of MAME roms are.... thats the point.... it uses MAME roms with AAE :) Its more simple than you think
Everything is set exactly the same way you run MAME only the artwork and the xml would be dif
If you have a complet MAME ROM set these come with all the games AAE has. So you do not even need not only and Emu, but the roms either. You already have/had them with your MAME setup... same goes for
Zinc
Neo Geo
CAVE
etc etc etc...
OMG..all I did was add the roms path to mame and it started working. WTH. Thank you so much. I can't believe this was causing me so much stress. I guess I just didn't really understand what AAE was as a system. Thanks so much!!!!
Hahah no problem at all. Took me a few times to get my head around it all.... thats why in my vids I make it so important to get some core systems installed... MAME, RetroArch and soon MESS
Once we have all the core systems installed you can sun almost anything you want just by enabling a system :)
