kat5200 issue
Cleggy6879
Hi all needing some help. I am having dramas with the kat5200 emulator. running the emu is not the issue its mapping the controller that im having dramas with. I am using 2 controllers and for some reason when I map these as controller 0 and controller 1 just before I save one of the allocated buttons on the player 1 controller maps to a controller 2 button. its driving me mad. has anyone had the same issue. Cheers in advance
I as well had a similar issue to yours when configuring Kat5200 with my X-Arcade controller a few years ago. From what I remember I went into each controller type (I think 4?) and mapped a non-used key within my configuration. I then saved the configuration to a profile name X-arcade. I then loaded the profile only only mapped Joy1 keys then re-saved the profile. This worked out for me :-) before I did this trick, the controller mappings drove me crazy and never worked no matter what I did. Hope it works out for you.
  • 3 weeks later...
HI do you run into problems not working in full screen when launching from HL & each time another window open together?
