Daphne Dragons Lair DLE21 Rom
Roverius
Hi,
I would like to change the dragon's lair rom from F2 to DLE21.
Somehow, if i run from hyperspin, it allways uses the default F2 rom.
No mather what i change, it keeps running on F2 instead of the DLE21
I made a BAT-file with the the DLE21 settings, and that worked perfectly.
So, my question is, how can i change the settings to point out to DLE21 rom
Module i use:
What file is used in %daphneParams% ?
The reason i want to use DLE21 is because it plays the bridge scene. in the F2 version, it skips the bridgescene.
;Laser Disk
;Daphne v1.0.6
;by Shaterdsoul
;1.0
;Info: Using Daphne.exe not tested with Daphneloader.
sleep, 1000
daphneParams = vldp -fullscreen -x 640 -y 480 -framefile
frameFilePath = %romPath%%romName%%romExtension%
Run, %executable% %romName% %daphneParams% "%frameFilePath%",%emuPath%,
Process, WaitClose, %executable%
ExitApp
CloseProcess:
return
Thanks for any support.
Regards,
Roverius
Hi,
I will asume by this module you are using HL2.  Just for grins, try changing your rom name from lair to dle21 and your framefile from lair.txt to dle21.txt.
Thanks,
Ron
Hi,
Module i use:
;Laser Disk
;Daphne v1.0.6
;by Shaterdsoul
;1.0
sleep, 1000
ExitApp
CloseProcess:
return
Regards,
Roverius
My DLE 2.1 works fine,if you still cant figure it out reply back and ill look into  my settings. I do remember changing the rom not only in daphne loader but also in either the HL ahk for daphne or somewhere else....
Renaming the bios rom in daphne from dl to dle21 will NOT work.
Not the bios rom.  The rom name in your database and the framefile.  Rename them to dle21 and the correct game will launch.
Anyway, I hacked up the module to give you some options.
;Laser Disk
;Daphne v1.0.6
;by Shaterdsoul
;1.0
custRomName = %romName%
If (romName == "lair") {
	custRomName = "dle21"
	daphneParams = vldp -fastboot -noissues -blank_searches -prefer_samples -fullscreen -x 640 -y 480 -framefile
} Else If (romName = "SomeRomName") {
	daphneParams = Some Params
Run, %executable% %custRomName% %daphneParams% "%frameFilePath%",%emuPath%,
ExitApp
CloseProcess:
return
So if you want to customize any other games, there is a section you can edit there and add some different parameters.
Hope this helps,
Ron
OK, got it working allready:
I copied the Framefile folder from "Lair" to "DLE21" ( i kept the lair folder for further use with the F2 rom)
I changed the name in the XML datafile from "lair" to "DLE21" also
<game name="dle21" index="true" image="d">
<description>Dragons Lair</description>
<cloneof></cloneof>
<crc></crc>
<manufacturer>Bally Midway</manufacturer>
<year>1983</year>
<genre></genre>
Renamed all media files, themes, etc... to DLE21.xxx also
just 1 small problem with the 1 player setting; if i set 5 lives/play, it plays unlimited lives in single player. In 2 player mode it works fine.
@RFANCELLA,
Yes i use (still) HL2.
I haven't tried RL for now (not sure if i gona mess up things)
Renaming the rom from LAIR to DLE21 is not working because it still uses the romfiles inside the ZIP file.
The thing i had to do was realy point out what romfiles the game needed to use.
In my Daphne folder i have a folder (also called roms) where there are unpakked romfiles.
So i just unpacked the DLE21.ZIP into that rom folder.
Anyway, thanks for the support/input/answers :)
Ok,
The rename was just to test.  If you use the module I posted, it will use the original names and just launch with the dle21 rom.  You can use the module and change the names back.
The other reason to use the modified module is to allow you to customize each game and how it launches.
So, for example, if you want those settings for player 1, change this line:
	[b]daphneParams = vldp -fastboot -noissues -blank_searches -prefer_samples -fullscreen -x 640 -y 480 -framefile[/b]
To:
	[b]daphneParams = vldp -fastboot -noissues -blank_searches -prefer_samples -bank 0 11011000 -fullscreen -x 640 -y 480 -framefile[/b]
And test.   ;)
This is how I got there:
Open DaphneLoader.
Select Dragon's Lair on the left.
Hit the configure button.
Select the Advanced tab.
Change Display Command Line to Enabled.
Now go back to the other tabs and make adjustments as you need.
Hit OK.
Then launch the game in DaphneLoader.
So, with every setting as default, the command line is:
daphne.exe dle21 vldp -framefile H:\Roms\Daphne\framefile\lair.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir G:\Emulators\Daphne -bank 0 11111000 -bank 1 00110111 -sound_buffer 2048 -x 640 -y 480
With just the number of "guys" per play changed, the command line is:
daphne.exe dle21 vldp -framefile H:\Roms\Daphne\framefile\lair.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir G:\Emulators\Daphne -bank 0 11011000 -bank 1 00110111 -sound_buffer 2048 -x 640 -y 480
The difference being the -bank 0 settings.  So I added that to the module for just lair.  ;)
Clear as mud?
Thanks,
Ron
PS:  All of these settings and customization are easily adjustable in HyperLaunch3/RocketLauncher and HyperLaunchHQ. ;)
<cloneof></cloneof>
<crc></crc>
<year>1983</year>
<genre></genre>
@RFANCELLA,
OK,
I tried the module you provided and change the name back to its original.
But when i start, it seems to have some problems.
Daphne log:
--DAPHNE version 0.99.7
--Command line is: H:\Hyperspin\Emulators\Daphne\daphne.exe dle21 vldp -fastboot -noissues -blank_searches -prefer_samples -fullscreen -x 640 -y 480 -framefile H:\Hyperspin\Emulators\Daphne\framefile\lair.txt
--CPU : GenuineIntel 3300 MHz || Mem : 4096 megs
--OS : Windows XP/.NET || Video : NVIDIA GeForce GTX 660
Unknown command line parameter:
-fastboot
-noissues
-prefer_samples
Setting screen width to 640
Setting screen height to 480
Bad command line or initialization problem (see daphne_log.txt for details).
To run DAPHNE, you must specify which game to run and which laserdisc player you are using.
For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode.
I changed the module a bit. Seems to work now
;Laser Disk
;Daphne v1.0.6
;by Shaterdsoul
;1.0
daphneParams = vldp -fullscreen -x 1024 -y 768 -framefile
daphneParams = vldp -fullscreen -x 640 -y 480 -blank_skips -blank_searches -useoverlaysb 2 -noserversend -framefile
ExitApp
CloseProcess:
return
Ahhh...  Those options are in the newer version of Daphne emulator.
I am running v1.0.12
I would recommend updating to the newer version.
Thanks,
Ron
;Laser Disk
;Daphne v1.0.6
;by Shaterdsoul
;1.0
ExitApp
CloseProcess:
return
