how to select own BIOS in Demul
silverfox0786
Does any one know how I can set my bios in Demul so the HyperLaunch AHK files does not change it back to Auto Region as it keeps doing
I know how to use demul.ini but the actual AHK module keeps changing it back and I cant work out how to set hyperspin to keep it to the one I specify
Thanks
	IniWrite, 1, %demulFile%, main, region ; Set BIOS to Auto Region
} Else {	; all other systems, Naomi and Atomiswave
	; This updates the demul.ini with your Bios choice for the selected rom
	If ( Bios != "" and Bios != "ERROR" ) {
		Bios := RegExReplace(Bios,"\s.*")	; Cleans off the added text from the key's value so only the number is left
		IniWrite, false, %demulFile%, main, naomiBiosAuto	; turning auto bios off so we can use a specific one instead
		IniWrite, %Bios%, %demulFile%, main, naomiBios	; setting specific bios user has set from the moduleName ini
	} Else
		IniWrite, true, %demulFile%, main, naomiBiosAuto	; turning auto bios on if user did not specify a specific one
cool I will try that.
although from the module it seems ther eis a way djvj wrote the module that it is possible to set it I just cant figure out how
this is what needs changing
  • 1 year later...
I know this is most likely necro'ing an old thread but since it's taken me awhile to work out the issue I thought I'd save people the time.
To set the bios for each game so that it stops using autobios you can do either of these.
Once you have demul setup in rocketlauch select sega naomi (its the same for sammy)
click the emulators tab, select demul in the emulator (of whatever you called it)
click edit global module settings
click on Rom setttings and add the game then set the bios at the bottom.
This can take some time to add all the roms in.
The other way is to open Hyperspin\Rocketlauncher\Modules\Demul|demul (0.7).ini
Copy and paste the information in the window below  into this file.
Please note this sets the bios to English for everything I've tested and will save you having to set it yourself.
I'm having issues getting vf4 to work for some reason it keeps defaulting to Japan. Will need to find out where the issue is.
I hope this saves someone some time.
[Settings]
Bios=8 - Naomi epr-21577h (USA)
LastControlUsed=standard
ListSorting=true
InternalResolutionScale=1
ShaderNamePass1=FXAA
ShaderUsePass1=true
Plugin=gpuDX11
Fullscreen=truefullscreen
[capsnk]
[vf4]
Bios=35 - Naomi 2 epr-23608c (Export)
[cspike]
Controls =standard
ListSorting=true
[mbaa]
Controls =standard
ListSorting=true
Bios=0 - Naomi epr-21576h (Japan)
[pjustic]
Controls =standard
ListSorting=true
[sl2007]
LoadDecrypted=
Controls=standard
ListSorting=true
[confmiss]
Controls =standard
ListSorting=true
[dygolf]
Controls =standard
ListSorting=true
[lupinsho]
Controls =standard
ListSorting=true
[meltyba]
Controls = ggxstyle
ListSorting=true
[meltybld]
Controls =standard
ListSorting=true
[mok]
Controls =standard
ListSorting=true
[demofist]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[dirtypig]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[dolphin]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[fotns]
Controls =standard
Plugin = gpuDX11
ListSorting=true
[ftspeed]
Plugin = gpuDX11
Controls=driving
ListSorting=true
[ggisuka]
Controls =standard
Plugin = gpuDX11
ListSorting=true
[ggx15]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[kofxi]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[kofnw]
Controls =standard
Plugin = gpuDX11
ListSorting=true
[kofnwj]
Controls = sfstyle
Plugin = gpuDX11
[kov7sprt]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[maxspeed]
Plugin = gpuDX11
Controls=driving
ListSorting=true
[mslug6]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[ngbc]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[rangrmsn]
Controls = lightgun
Plugin = gpuDX11
ListSorting=true
[rumblef]
Controls =standard
Plugin = gpuDX11
[rumblef2]
Plugin = gpuDX11
Controls=standard
ListSorting=true
[salmankt]
Plugin = gpuDX11
[samsptk]
Plugin = gpuDX11
Controls=standard
[sprtshot]
Controls =standard
Plugin = gpuDX11
ListSorting=true
[vfurlong]
Plugin = gpuDX11
[xtrmhunt]
Controls =standard
Plugin = gpuDX11
ListSorting=true
[xtrmhnt2]
Controls =standard
Plugin = gpuDX11
ListSorting=true
[ggram2]
Controls=standard
ListSorting=true
[gram2000]
Controls=standard
ListSorting=true
[gwing2]
Controls=standard
ListSorting=true
[illvelo]
Controls=standard
ListSorting=true
[toukon4]
Controls=standard
ListSorting=true
[vs2_2k]
Controls=reverse
ListSorting=true
[vtennis]
ListSorting=true
Controls=standard
[wrungp]
Controls=wldrider
ListSorting=true
[zerogu2]
Controls=standard
ListSorting=true
[spkrbtl]
Controls=standard
ListSorting=true
[tetkiwam]
Controls=standard
ListSorting=true
[vtennis2]
Controls=standard
ListSorting=true
[asndynmt]
Controls=standard
ListSorting=true
[ausfache]
Controls=standard
ListSorting=true
[azumanga]
Controls=standard
ListSorting=true
[bdrdown]
Controls=standard
ListSorting=true
[cfield]
Controls=standard
ListSorting=true
[cleoftp]
Controls=standard
ListSorting=true
Bios=14 - Naomi epr-21578g (Export)
[zombrvn]
Controls=standard
ListSorting=true
[wwfroyal]
Controls=standard
ListSorting=true
[deathcox]
Controls=standard
ListSorting=true
[trgheart]
Controls=standard
ListSorting=true
[csmash]
Controls=standard
ListSorting=true
[cvs2gd]
Controls=standard
ListSorting=true
[doa2]
Controls=standard
ListSorting=true
[hotd2]
Controls=standard
ListSorting=true
[ggx]
ListSorting=true
Controls=standard
[chocomk]
Controls=standard
ListSorting=true
[ggxx]
ListSorting=true
Controls=standard
[ggxxac]
Controls=standard
ListSorting=true
[ggxxrl]
Controls=standard
ListSorting=true
[ggxxsla]
Controls=standard
ListSorting=true
[gundmgd]
ListSorting=true
Controls=standard
[gundmxgd]
ListSorting=true
Controls=standard
[gunsur2e]
ListSorting=true
Controls=fps
[virnbao]
ListSorting=true
Controls=standard
[jingystm]
ListSorting=true
Controls=standard
[ikaruga]
ListSorting=true
Controls=standard
[karous]
ListSorting=true
Controls=standard
[kurucham]
Controls=standard
ListSorting=true
[mamonoro]
ListSorting=true
Controls=standard
[mbaaa]
ListSorting=true
Controls=standard
[meltyb]
ListSorting=true
Controls=standard
[monkeyba]
ListSorting=true
Controls=sfstyle
[mvsc2]
Controls=standard
ListSorting=true
[otrigger]
Controls=standard
ListSorting=true
[pstone]
ListSorting=true
Controls=standard
[pstone2]
ListSorting=true
Controls=standard
[shikgam2]
ListSorting=true
Controls=standard
Bios=13 - Naomi epr-21578h (Export)
[slasho]
ListSorting=true
Controls=standard
[sprtjam]
ListSorting=true
Controls=standard
[ss2005]
ListSorting=true
Controls=standard
[sstrkfgt]
ListSorting=true
Controls=segastrikefighter
[starseek]
Controls=standard
ListSorting=true
[takoron]
ListSorting=true
Controls=standard
[toyfight]
ListSorting=true
Controls=standard
[undefeat]
Controls=standard
ListSorting=true
[vathlete]
ListSorting=true
Controls=standard
[spawn]
Controls=standard
ListSorting=false
[hmgeo]
Controls=standard
ListSorting=true
[vstrik3c]
Controls=standard
ListSorting=true
Bios=31 - Naomi 2 epr-23607b (USA)
[trizeal]
Controls=standard
ListSorting=true
[ninjaslt4]
Controls=Standard
ListSorting=true
[vonot]
Controls=samba
ListSorting=true
