problem with visual pinball
handsome1987
Hey
I have a problem with visual pinball in hyperpsin.
When i select a table it plays fine.
But when i close the table and want to select a new table i get this error:
there was an error waiting for the window ahk_class to become active
Also hyperlaunch doesn't close it will be active in the taskbar.
Can anyone help me?
welcome to the forum and
1. make sure you have VP.exe  running with admin privileges.
allot of errors are generated because windows places restrictions on the program.
2. Open  VP go to
Preferences --> keys -->  look for the " Disable ESC key" and make sure you have a check on it.
if you launch a table outside of Hyperspin use the "Q" to exit
if you launch a table WITH Hyperspin/Rocketlauncher use the key(s) you usually use to exit your games  (mine is ESC).
you may need to do some per module settings,  but that depends on your system.  hopefully this fixes your problem.
if you running the latest version of the module and have ESC disable in VP.
you will need to edit the module settings.
Go to HyperlaunchHQ  --> Global Settings --> Click emulators tab --> select your Global VP emulator --> click on
"Edit Global Module Settings"
you will have to play with this settings
EscClose= True/false
Show DMD = True/Flase
ValidateDMDLaunch = True/false
UpdateDefaultDMD = true/false
this is what I have, start from here and see if your problems are fixed.
Hey 32 assassin thank you for your reaction.
I was going to tried what you told me but when i click on edit global module settings i got this error : module doesn't have an associated isd file.
So i think my problem starts here.
Can u help me?
